IE8's problem
MY internet explore often "encountered a problem and needs to close". I click "Don't send" error report. Then "This tab has been recovered" by itself. :no:
Why. How can I solve this problem? Thanks.
I have used IE8 for at least 6 or 7 months. It always works well. I don't know why it encounters such a problem suddenly.
You have a couple options. First look into the Event Viewer under either Application or Internet Explorer and see if there are any events with some detailed information. Also, you may have to install the Debugger and get the Symbols for your OS to get a memory dump from IE when it crashes.
Does it always do this on the same website? Or maybe when you are on a page with either Java or Flash?
