Emperor Nicon Posted May 21, 2009 Posted May 21, 2009 (edited) Ive tried use a reg file to duplicate these settings but I try they do not work. regedit says it has been entered successfully but it doesnt show up at all even after reboot so when i install windows all over again i dont want to uncheck a bunch of boxes every timethe pic on the left is the focus but the middle and right are the settings i want to include in my unattended installation diskhere are the supposedly keys associated with these settings:[HKEY_CURRENT_USER\Software\Microsoft\Windows\ShellNoRoam\Bags\7\Shell]"ScrollPos800x600(1).y"=dword:00000002[HKEY_CURRENT_USER\Software\Microsoft\Windows\ShellNoRoam\Bags\1\Shell]"ScrollPos800x600(1).y"=dword:00000000[HKEY_CURRENT_USER\Software\Microsoft\Windows\ShellNoRoam\MUICache]"@C:\\WINDOWS\\system32\\mycomput.dll,-400"="Mana≥""@C:\\WINDOWS\\system32\\SHELL32.dll,-8503"="S&earch...""C:\\WINDOWS\\Explorer.EXE"="Windows Explorer"[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\UserAssist\{75048700-EF1F-11D0-9888-006097DEACF9}\Count]"HRZR_EHAPCY"=hex:01,00,00,00,0A,00,00,00,80,CC,90,F4,32,DA,C9,01"HRZR_EHAPCY:FLFQZ.PCY"=hex:01,00,00,00,08,00,00,00,80,3D,93,F4,32,DA,C9,01[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"ListviewAlphaSelect"=dword:00000000"TaskbarAnimations"=dword:00000000[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\VisualEffects]"VisualFXSetting"=dword:00000003[HKEY_CURRENT_USER\Control Panel\Desktop]"DragFullWindows"="0""UserPreferencesMask"=hex:98,12,03,80[HKEY_CURRENT_USER\Control Panel\Desktop\WindowMetrics]"MinAnimate"="0"[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Cryptography\RNG]"Seed"=hex:7E,B1,99,EC,32,C8,2D,59,DA,BB,17,DF,22,AB,74,EA,\DD,8D,81,23,7B,A2,D3,E7,A5,9D,F6,DF,3E,C7,91,B2,\B0,2E,0F,21,5B,EF,97,A9,8B,ED,CB,5C,35,00,C0,A2,\47,66,A9,FF,3F,0B,13,94,F9,3E,03,F3,44,14,88,4E,\6F,26,F9,90,DA,B1,65,45,69,50,59,CA,F0,08,B2,4Calso i use runonceex to set the tweaks Edited May 23, 2009 by Emperor Nicon
radix Posted May 21, 2009 Posted May 21, 2009 The next should work:Windows Registry Editor Version 5.00[HKEY_CURRENT_USER\Control Panel\Desktop]"FontSmoothing"="2"[HKEY_CURRENT_USER\Control Panel\Desktop\WindowMetrics]"MinAnimate"="0"
Emperor Nicon Posted May 21, 2009 Author Posted May 21, 2009 I tried it it doesnt get that result i need, sorry
Yzöwl Posted May 26, 2009 Posted May 26, 2009 The only settings you should be changing are these:[HKEY_CURRENT_USER\Control Panel\Desktop]"DragFullWindows"="0""UserPreferencesMask"=hex:98,12,03,80[HKEY_CURRENT_USER\Control Panel\Desktop\WindowMetrics]"MinAnimate"="0"[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"ListviewAlphaSelect"=dword:00000000"TaskbarAnimations"=dword:00000000[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\VisualEffects]"VisualFXSetting"=dword:00000003If using RunonceEx doesn't work for you perhaps you should add the registry changes after that followed by a reboot or before it by directly modifying the appropriate hive file.
