mold Posted March 14, 2009 Posted March 14, 2009 (edited) i'm running the 7057 build of x64 Win 7. i have the v103 win7codecs installed, and the v105 win7x64components.when i try to play avi files uisng Media Center, most of them work but for some of them the video works but i get no audio. there are no software errors displayed, but my Sharp LCD TV displays the following error: "An incompatible audio signal has been received. Check the output device settings." the TV is connected to the HTPC using HDMI.these same avi files play ok using vlc or graphstudio. any suggestions on what i need to tweak to fix this?thanks. Edited March 14, 2009 by mold
spacesurfer Posted March 14, 2009 Posted March 14, 2009 i believe the media player (which is used by media center) is still a beta and they are working on video playback.i had a problem playing an avi full screen with media player. i got audio but no video and moreover, the keyboard wouldn't work. i had to cold reboot. the video played fine in media player classic.anyway, i don't think a tweak will fix it. might just have to wait for future builds before things are worked out.
BoardBabe Posted March 15, 2009 Posted March 15, 2009 I believe the audio drivers in current Windows 7 builds are not working properly, this may cause problems on certain audio devices. I have personally encountered unrepairable audio problems using SPDIF TOSLink with external creative X-Fi sound card.
nitroshift Posted March 15, 2009 Posted March 15, 2009 @mold: Build 7057 is a leaked build, thus warez. You will not get help here with warez. Please read the forum rules before posting. Thank you!
BoardBabe Posted March 15, 2009 Posted March 15, 2009 The problem is reported to Microsofts feedback program with ID 420642. Please comment, comfirm and vote to help Microsoft correct the issue. Simple registration required.
