Problem with slipstreaming SP3 on SP2 Pro OEM french
Hi everyone,
So, I've been trying an SP3 clean disk about 3 days and I haven't found any solutions. My problem is my key (classic OEM key buy with my computer) is not valid when I include SP3 with nLite 1.4.5.4 under XP Pro SP2 or Vista HP SP1.
Which kind of informations do you need to help me for making a SP3 disk ?
Thanks for your help !
EDIT : topic description
Edited by nextdrOp
Thanks nuhi to get interest.
My key works fine under a nlite SP2 with tweaks, etc.... If I included SP3, my key doesn't work anymore. It's an official... I can send you a picture of it if you want.
I'll try just to slipstream and 1 driver (ICH9R RAID) without any tweaks or options. I'll come back after.
My conf: Gigabyte P35-DS3P Rev 1.0 / E6600 / 2Go / 2x 74Go / 8800 GTS
Edited by nextdrOp
some times when releasing a new service pack microsoft also blocks keys that they consider as unlegitimate....that means your key was used more then the license u have permited... so blame microsoft not nlite for this.
I'm certainly not blaming nLite. I only use one time my key...
Like you said, maybe it's microsoft's fault. I'll try at work with each computer.
Thank you for taking time for me.
nextdrOp
Since you have the same issue under XP or Vista then it is the key problem, not the slipstream.
Ok, I have to apologize, I only have a key problem using nLite 1.4.5.4 under Vista Home Premiun SP1
I've just try an other nLite version using a fresh xp sp2 install (using nLite) and it's work fine in Parallels.
So maybe there is still a little problem under Vista... thanks for your apps!
