Hey, I've been wondering can I define variable that contains words separated with spaces, then use FOR to go through the string and echo every token?
@echo off
REM DEFINE THE HOSTS THAT SHOULD BE SKIPPED (SEPARATE WITH SPACE)
set DISCARD=DC1 DC2 MGW
FOR /F "delims= " %%a IN ('@echo %DISCARD%') DO @(
echo DISCARDED : %%a
but this only echoes the word before the first space.
C:\>skip.cmd
DISCARDED : DC1
C:\>
I know that I could use a text file containing all the words separated with new lines, but for the sake of simplicity I want to define everything inside one variable. I understand that using the "tokens=" parameter I can capture the amount I want from the line, but I just want to echo every token from the line and do something with them.
This is what I would like the output to be:
C:\>skip.cmd
DISCARDED : DC1
DISCARDED : DC2
DISCARDED : MGW
C:\>
Is this possible?
Cmd Promt is not my best langauge, but to do what you want would be simple in VBS script.
Save As Demo.vbs
Dim D1, D2, DISCARD
DISCARD = Array("DC1", "DC2", "MGW")
For Each D1 In DISCARD
D2 = D2 & "DISCARDED : " & D1 & vbCrLf
Next
MsgBox D2,4128,"Finish"
@ECHO OFF&SETLOCAL
:: DEFINE THE HOSTS THAT SHOULD BE SKIPPED (SEPARATE WITH SPACE)
SET DISCARD=DC1 DC2 MGW
FOR %%a IN (%DISCARD%) DO ECHO/DISCARDED : %%a
PING -n 6 127.0.0.1>NUL
@ECHO OFF&SETLOCAL
Exactly what I was looking for. Thank you! I just don't get what is the difference between FOR %%a IN (%DISCARD%) and FOR %%a IN ('echo %DISCARD%')
Th difference is
FOR %%a IN (echo %DISCARD%)
echo is a print command, so basically you are asking it to break down something being printed (how do you break down a command???) e.g. for <every part> of (print <variable>) is what you instructed it to do
break down the variable it its commpoent parts
e.g. for <every part> of (<variable>) is what you instructed it to do
