Problem: Performance Index for Alpha Blend etc.
Hi there,
I installed Vista Business 64 using Vlite beta 1.1 (not beta 2!)
I am not able to use Performance Index in order to achieve alpha blend features..
Silly as I am I used DTweak (optimization software). :realmad:
I already tried to insert
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Performance Control Panel
and
HKEY_CURRENT_USER\SOFTWARE\Policies\Microsoft\Windows\Control Panel\Performance Control Panel
and change PerfCplEnabled to 1
Does anyone have a solution? :hello:
Hi,
I inserted my VLite Vista Disk and searched for WinSAT and WMP ^^ unfortunately I did not found ANY of these! I checked the box saying "search for hidden non indexed files"....
What shall I do now? Can I add the files to Vista using orignal DVD? I WAS able to use performance index while Installing vista...
Hi,
thanks for your help!
I will make a new Vlite DVD... but I will definetly wait with reinstall because the Performance Index ist just a "Prestige" tool which does not have influence on games etc. :)
Cya
