Problem with Realtek HD audio drivers on unattended nlited xp cd
hi
for some reason i can get it to work on my updated xp disc, while my older xp setups (outdated) does work when i just use the orginal gigabyte express setup to install all the drivers.
ive looked for realtek in this board and i know that maybe its something to do with that KB888111 (Microsoft High Definition Audio) and i really dont know how i can fix that.
my only option is to use the old disc for now
or maybe make a new one with updated software but without the windows updates cuse i guess one of them makes that problem maybe KB935448? but i tried to remove only KB935448 and still had that problem..
i hope someone can help me
thanks
Edited by Triple-z
If you're using the driverpacks, I've had the same problem recently. The only thing I could do was manually install the drivers & create my own customized driver pack for my computer.
no i dont use the driver pack, what i mean is that after i install my new xp on a pc with realtek hd audio driver i can get the driver to work even when i use the orginal driver cd of the motherboard..
only if i use my old xp cd from 2006 without the latest winupdates its workin and then i need to update windows myself..
