[SOLVED]winpe shell problems
I got some trouble with WinPE, build with WinBuilder and VistaPE. I'm trying to use winpeshl.ini to launch Litestep and some other programs (wpeinit for example).
This is the winpeshl.ini I want to use, located in \Windows\System32.
[LaunchApp]
AppPath=%SystemDrive%\Program Files\LiteStep\litestep.exe
[LaunchApps]
init.exe
Any idea what could be wrong?
I think I missed some details, so here comes a bit of explanation.
Litestep (Shell Replacement) gets started and is running. However, it looks like the LaunchApps section is not honored, independent of which application/s I added there, it just won't start them.
EDIT: see last post for the solution.
Edited by bj-kaiser
You can use this
[LaunchApp]
AppPath = %SYSTEMDRIVE%\Windows\System32\litestep.exe
or
[LaunchApp]
AppPath = %WINDIR%\System32\litestep.exe
You can put it pretty much anywhere but I suggest you put your shell in System32. It probably doesnt like your space in "Program Files".
Edited by paxamime
