nirgomer Posted November 10, 2006 Posted November 10, 2006 Hi people,in the past few days i've been getting the following message on the information bar when browsing to some sites :"Your security settings do not allow websites to use ActiveX controls installed on your computer. This page may not display correctly. Click here for options"These are sites that I used to go to daily without any problem or message popping...I'm using IE7and the settings for ActiveX are:Allow previously unused.... - disabledAllow scriplets - disabledAutomatic prompting - enabledBinary and scripts - enabledDispaly video and animation... - disabledDownload signed activex controls - promptDownload unsigned.... - disabledInitialize and script... - disabledRun activex controls and plugins - enabledScript activex controls marked safe for scripting - enabledAny idea if one of these settings are incorrect? (I didnt touch them before, but trying to play with them now... no success)thanks
LLXX Posted November 11, 2006 Posted November 11, 2006 Disabled? That's a good thing.http://www.msfn.org/board/index.php?showtopic=86132
nirgomer Posted November 12, 2006 Author Posted November 12, 2006 hmm hmmOk...but.. that doesn't solve the problem..?i'm confused (that's probably the booz's fault also )is there anything i can do to make that message disappear?
LLXX Posted November 13, 2006 Posted November 13, 2006 You could try adding the site to the Trusted Sites zone, but be careful... unless it's a site you really trust, you might get really infected.If the site still looks fine and everything seems to work then there is no concern at all. I get that warning a lot when browsing, and to me it's just telling me that it's stopped something potentially malicious from infecting my machine
nirgomer Posted November 14, 2006 Author Posted November 14, 2006 ok LLXXi'll just let that message show up. if you can take it, i can too thanks!
