Jig Saw Posted November 1, 2006 Posted November 1, 2006 Is there a way to fix this problem. Some menus aren't correct on my widescreen 21" Gateway as they were on my 19" LG 4:3. I'm missing text and options specifically with my creative thx menu . Any help would be appreciated. i did uninstall and reinstall the software suite with no luck.
DigeratiPrime Posted November 1, 2006 Posted November 1, 2006 what software has this problem or is it system wide? it might be related to the dpi setting.
Jig Saw Posted November 1, 2006 Author Posted November 1, 2006 (edited) I did change the dpi to 120 ill reset to default and report backChanging the dpi back to default of 96 solved the problem. Thanks for the help. Edited November 1, 2006 by Jig Saw
