Solution to localization problem
Hi,
I see a lot of people having problem with the localization of their Windows. I am not talking of the problem with the box opening and asking for name and location, but specifically where Windows reports your location under Regional and Language Options.
Seems that if you select these settings manually creates the problem. If you only select language in nlite and then stay with the default, everything goes fine. Anyone able to do a test install to verify that it's not just my version of windows?
I'm installing Win XP Pro VL with Norwegian locale.
