Buncha Of Problems ...! Please Help
:no: Hey Guys :
I Have some problems with My unattend Cd :
1. The Taskbar when i first run My Windows is too high !
2. I Don't Have Except One User Called Adminstrator ( I Need One More )
3. I Tried To Install Some Fonts Using A WinRAR Archive (I made My Self) But Windows Doesn't Take Them
4. The Reg Patch To Change WinLogon Doesn't Work
And Here is My Batch File
@echo off
title Windows XP Service Pack Lieth
echo Windows XP SP2 Lieth Edition
echo Installing Applications Please Wait...
echo The Computer Will Auto-Reset Once The
echo Operation is Done...
echo.
ECHO Removing useless shortcuts...
DEL "%systemdrive%\Documents and Settings\All Users\Start Menu\Windows Update.lnk"
DEL "%systemdrive%\Documents and Settings\All Users\Start Menu\Set Program Access and Defaults.lnk"
Echo.
Echo Applying Registry Tweaks
REGEDIT /S %systemdrive%\install\hklm.reg
Echo.
Echo Installing Sounds...
Start /wait %systemdrive%\install\Sounds.exe
Echo.
Echo Installing Fonts...
Start /wait %systemdrive%\install\Fonts.exe
ECHO.
ECHO Installing Microsoft Office 2003 Professional
ECHO Please wait...
start /wait %systemdrive%\install\2003\setup.exe TRANSFORMS=Unattended.MST /qb-
ECHO.
ECHO Registering Nero...
REGEDIT /S %systemdrive%\install\Nero\register.reg
ECHO.
ECHO Installing Nero 6 Ultra Edition...
ECHO Please wait...
start /wait %systemdrive%\install\Nero\Nero.exe /silent /noreboot
echo.
echo Installing Arabic Dictionary...
start /wait %systemdrive%\install\AraDic.exe
echo.
echo Installing WinRAR...
start /wait %systemdrive%\install\WinRAR\wrar.exe /s
echo.
echo Installing K-Lite Mega Codecs Pack...
start /wait %systemdrive%\install\Codec.exe /VERYSILENT /SPECHO.
ECHO Killing Codec.exe process
taskkill.exe /F /IM Codec.exe
ECHO.
echo.
echo Installing Windows Media Player 10
start /wait %systemdrive%\install\WMP10\MP10Setup.exe /q:A /c:"setup_wm.exe /Q /R:N /DisallowSystemRestore"
echo.
echo Installing Rocket Launcher...
start /wait %systemdrive%\install\RK.exe
echo.
echo Patching WinRAR...
start /wait %systemdrive%\install\winrar\wrarp.exe /s
ECHO.
ECHO Restarting the PC in 1 minute...
shutdown.exe -r -f -t 60 -c "Windows XP will now restart in 1 minute, this will give enough time for the
shortcuts to update and for the shell to fully load before its ready to restart!"
ECHO.
ECHO Deleting Temp Installation Files...
RD /S /Q %systemdrive%\Drivers
RD /S /Q %systemdrive%\install
EXIT
Thanks All :}
I have no idea on how to solve the problem #1 but:
2)You can create as many users you wish via cmdlines.txt.This is how:
create a users.cmd file in notepad with the following
net <username> <password> /add
net localgroup Administrators <username> /add
exit
e.g.
net jim kick /add
net localgroup Administrators jim /add
exit
This will create and add jim's account to Administrators with "kick"as a password.
3)Place your fonts inside $OEM$/$$/Fonts so as to have them copied over and installed after setup.
4)I suppose you mean the logonui.exe file...Do this:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"UIHost"="%windir%\\system32\\logonui2.exe"
I don't know if it works.Just a suggestion
