janus zeal Posted April 20, 2006 Posted April 20, 2006 i have an ESS Allegro es1989s sound card. it plays sound, but i have a problem. in the volume panel the master volume slider stays all the way down. i can move it to the top, but then it just goes back down by its self. any ideas? im thinking its a driver issue of some kind, but i cant find any place to find drivers other then driverguide (and this is the only one they have for it)any ideas?
Aegis Posted April 20, 2006 Posted April 20, 2006 Is that integrated sound? If it is, try getting a cheap PCI-based sound card.
janus zeal Posted April 20, 2006 Author Posted April 20, 2006 Heh, this is the cheep PCI sound card. >_< i guess get another one? or try to find diffrent drivers?im a hugh windows 98 fan, but these wierd problems are makeing me think about win2k...
hankjrfan00 Posted April 20, 2006 Posted April 20, 2006 Heh, this is the cheep PCI sound card. >_< i guess get another one? or try to find diffrent drivers?im a hugh windows 98 fan, but these wierd problems are makeing me think about win2k...Why not try the drivers from the manufacterers site here.You should only get drivers from places like driverguide if yo can not find them one the manufacterers site.Also if it is a driver problem you should not blame it on the os.
janus zeal Posted April 20, 2006 Author Posted April 20, 2006 Also if it is a driver problem you should not blame it on the os. normally i wouldnt blame it on the OS, but ive had a half a dozen wierd problems... and when i tryed the ess site was down... thank you tho
