Newbie problems i think... :blink:
I want to change desktop resolution, because parameters in winnt.sif doesn't work. So, i put 1365VidChng.exe into my unattended install folder ...$OEM$\$$\System32\1365VidChng.exe
And added such line to winnt.sif -
[GuiRunOnce]
1365VidChng.exe 1024x768x32@60 -q
%Systemdrive%\Install\XPlode.exe
When i wanted to reinstall windows, a message poped up - it said : error in line 160, (so i counted, this line - 1365VidChng.exe 1024x768x32@60 -q ), setup cannot continue, and will exit...
What's the problem? Maybe i need to create some batch files? So can somebody say how to make it work? What procedures should i take? Maybe some examples how to make 1365VidChng batch file and where to put it?
Thanx in advance.... :}
I change the screen resolution at the 13 min mark using cmdlines.txt and a batch file.
In the UserAcount.cmd I have a this entry, I have change the name of 1365VidChng.exe
to this VidChng.exe. I have all of this in my $OEM$ folder.
Cmd I use to use VidChng.exe
start VidChng.exe 1024x768x32@85 -q
[COMMANDS]
"REGEDIT /S MediaPlayer-HK_U_D.reg"
"REGEDIT /S wmp10.reg"
"REGEDIT /S 000.reg"
"REGEDIT /S 020.reg"
"REGEDIT /S 040.reg"
"REGEDIT /S 060.reg"
"REGEDIT /S 080.reg"
"UserAcount.cmd"
"UaPrestart.cmd"
"RunOnceEx.cmd"
In my Winnt.sif I have this
[Display]BitsPerPel=32
Xresolution=1024
YResolution=768
Vrefresh=60
By the way can i use this command in winnt.sif Like this -
[GuiRunOnce]
%SYSTEMROOT%\SYSTEM32\1365VidChng.exe 1024x768x32@60 -q
If my 1365VidChng.exe is in ...$OEM$\$$\System32\1365VidChng.exe ? It gonna work?
Try this
Save as ChangeRes.cmd
@Echo Off && CLS && Mode 65, 5 && Color && F3 && Title Change Screen Resolution
start /w %SYSTEMROOT%\SYSTEM32\1365VidChng.exe 1024x768x32@60 -q
Then place that in ...$OEM$\$$\System32\ChangeRes.cmd so it gets copy to there.
[GuiRunOnce]
%SYSTEMROOT%\SYSTEM32\ChangeRes.cmd
Try this
[GuiRunOnce]%SYSTEMROOT%\SYSTEM32\ChangeRes.cmd
@gunsmokingman
hi tried your method but still didn't work...
here's my winnt.sif config
[Display]
BitsPerPel=32
Xresolution=1024
YResolution=768
Vrefresh = 60
AutoConfirm=1
[GUIRunOnce]
command9 = "%SystemDrive%\D\BTS_DPs_finish.cmd"
%systemroot%\system32\ChangeRes.cmd
%systemdrive%\install\wpi\wpi.exe
btw
i put the 1365VidChng.exe and ChangeRes.cmd in $oem$\$$\system32\
Edited by treblA
1:\ Does this get copy to %SYSTEMROOT%\SYSTEM32\ChangeRes.cmd
2:\ Does your Video Card support the resolution, and how are you installing drivers for it.
1. yes i thinks so...cause i put ChangeRes.cmd in $oem$\$$\system32 also 1365vidchng.exe
2. Yes cause after the installation i manually change it to 1024x768 and it works fine....
