3gonus Posted December 26, 2005 Posted December 26, 2005 I have an nlited version of xp2, without the usb audio support. I bought a webcam with inner microphone,i install it but i can use only the cam for video, not the include microphone, because there is a driver error (deleted usb audio xp support.There is a way to install usb audio xp support without reinstall another version of xp? Maybe registering some files extracted from cabs?Thank you in advance, 3gonus
Gouki Posted December 26, 2005 Posted December 26, 2005 Well, first this should be posted on the nLite forums. not here!About your problem:It may be possible to get USB Audio support back, however, it wont be easy! Actually, it will be VERY hard.The best thing you can do, is install one version of XP that has the USB Audio support.
3gonus Posted December 26, 2005 Author Posted December 26, 2005 Well, first this should be posted on the nLite forums. not here!About your problem:It may be possible to get USB Audio support back, however, it wont be easy! Actually, it will be VERY hard.The best thing you can do, is install one version of XP that has the USB Audio support.its hard,i know... but which is the way?explain me please... ;-)thank you very much
