alfax76 Posted November 24, 2005 Posted November 24, 2005 I am having a problem with the end user license agreement whenm installing 2003 server standard, i am testing the multi boot in virtual pc and this is what appears to me, could anyone help me out? I already checked in i386 directory and the eula.txt is there!
amd64lover Posted November 25, 2005 Posted November 25, 2005 if you are using a unattended setup and have a winnt.sif file, you can insert "OemSkipEula = Yes" under the "[unattended]" section.....
LiquidSage Posted November 25, 2005 Posted November 25, 2005 (edited) make sure that txtsetup.sif is pointing to the right OS folderMost people forget to add a '\' at the end ofSetupSourcePath = ex -SetupSourcePath = "\SETUP\XP\pro1\" Edited November 25, 2005 by LiquidSage
