liquidator87 Posted July 14, 2005 Posted July 14, 2005 (edited) Hello, I've used the switch /bootlogo in boot.ini to load custom bootscreens, but the last I have tried has something wrong.For some reason, when at boot time it shows the image, it has a white border all around, which shoudn't be there. This happens only with this image (I've attached it), all others I've tried works perfectly. Perhaps you could try it out and see if it causes you the same problem. If anyone can help me, thanks in advance...Here Is The Bootscreen Edited July 14, 2005 by liquidator87
Zxian Posted July 21, 2005 Posted July 21, 2005 For all boot screens, I recommend using BootSkin. It's a simple app that you can easily write your own boot screens for and if anything goes wrong, you can always get into Safe Mode and select another bootscreen.Try seeing if that app will correctly display your picture (to which the link is broken BTW).
liquidator87 Posted July 27, 2005 Author Posted July 27, 2005 Strange... I can get the image clicking on it... maybe I need another Image-hosting service...
Zxian Posted July 27, 2005 Posted July 27, 2005 Ok... the picture works now. If you want another image hosting service, XPerties put up an Image Host server a while back. Check in the General Discussion section for the thread (Titled "Not a plug" or something like that.
