Please please please can someone help me with my unattended Nortons files???
All i am doing is installing norton inteernet security 2005 and norton system works premier 2005 silently with default options. What i need to know is, how do i cut some of the junk out becuase i really need to reduce the size of these programs.
I am not using ANY of the use from cd options just default install.
@kelsenellenelvian
To slim the install down I would just delete the directories in NSW2005 that you aren't going to install. So if you delete all the directories except for NSW and NU, when you run the installer it will detect that the programs aren't there and not install them. You don't need to install NAV from systemworks as it's in NIS2005. Hope that helps
Raiden.
