wannamax Posted November 16, 2004 Posted November 16, 2004 Hmm...That way doesn't work for me.However, simply put on your original Win XP CD (SP2) and select upgrade your window,After done, installing DirectX 9.0c...It works properly!
solution Posted December 7, 2004 Posted December 7, 2004 Solution:1. Va dans proprièté, paramètres, et mets la qualité de la couleur en "moyenne". 2. Va dans demarrer et clique avec le bouton droit de la souris sur les sims deux puis clique sur propriété. Va dans la partie racourci et la ou y a écrit cible il devrait y avoir quelque chose comme: "C:\Program Files\EA GAMES\The Sims 2\TSBin\Sims2.exe" après les guillemets fait un espace et écrit -w Voila c'est bonSolution:The following steps can be used to eliminate or minimize the issue(s) reported with the game: 1. Set the display to 16-bit color. To make this change, follow these steps: a. Click on the Start menu and select Settings, Control Panel, and then double-click on Display. If using Microsoft Windows* XP: Click on the Start menu and select Control Panel, "Switch to Classic View" if the category view is shown, and then double-click on Display.b. Select the Settings tab.c. Change the Color Quality (Color Depth) to 16-bit color.2. Run the game with the -w switch which forces the game to run in a window. To add this switch, follow these steps:a. Right-click on the The Sims 2 game and left-click on Properties. You can do this either on the game's shortcut on the desktop or on the game's entry in the Start menu.b. Add a space and -w to the end of the Target fieldNote: The actual path may vary depending on where the game was installed. Make sure that the -w goes outside the quotation marks and that there is a space between the last quotation mark and the -w.c. Click OK.
DigeratiPrime Posted December 8, 2004 Posted December 8, 2004 I know this doesnt address your question, but if someone is looking for a way to share their neighborhoods with other users on a local machine I found a freeware program to do so here:http://www.rekenwonder.com/linkmagic.htmby default The Sims, and many other games, create a "EA Games" folder or something simliar in every users My Documents. Using this (LinkMagic) its possible to consolidate it into one folder for all users. This is also beneficial because it saves space.Might help someone.
nattygrlx92 Posted December 29, 2004 Posted December 29, 2004 thanks kazung, i'm going to try to use that reply...i hope it wokrs! It's not fair that for SOME it wokrs but not for others
gymnast9 Posted December 31, 2004 Posted December 31, 2004 I tried installing the sims 2 but now in order for it to work I need to Uninstall it but my computer won't let me! HELP ME!!
