Aland Posted August 22, 2004 Posted August 22, 2004 OK heres the problem i have Windows xp PRO. I slipstreamed SP1a into it. Then created the svcpack.inf and winnt.sif file. I also did a command file for Gui runonceso i have all updates installing up to now. When i try to install ANY scusi or raid driver through the floppy by pressing F-6 durring the beginning of the install the drivers are accepted by setup but latter says it cannot find the files durring the install. So i press enter to "Retry" and i watch the floppy drive get accesed but it still says it cannot find the files. I am so confused and i tried to include as much info as possible. Plese help !
gamehead200 Posted August 22, 2004 Posted August 22, 2004 12. Very often we see meaningless subjects in topic title. They give no clue of what the posts are all about. For example:- Oh no!- Help- I'm mad- Please help- Question- I need your help- Hmmmm ....This should be avoided. Users should enter something more specific in topic title so that it is easier for others to help.A few good examples:- Strange problem with DirectX9b redist- RunOnceEx install problem (double installation)- Change Internet Explorer's Icon back to default
