brian873 Posted June 7, 2004 Posted June 7, 2004 After creating my 1st slip streamed cd with many thanks to this site; the only problem i have left is a nagging dialog box.It appears when installing the hot fixes and I believe after WMP9MM2.EXE has been installed.The dialog box comes withTitle = Choose directory for Extracted FilesBox = C:\windows\system32\inetsrvButtons = OK - Cancel – BrowseIf I OK it I get another box sayingTitle = Extraction CompleteMessage = Extraction CompleteButtons = OKWhen I OK this the installation completes and windows works fine.Have I missed something stupid or does anyone else have this problem ?My SVCPACK file[Version] Signature="$Windows NT$"MajorVersion=5MinorVersion=1BuildNumber=2600[setupData]CatalogSubDir="\i386\Update"[ProductCatalogsToInstall][setupHotfixesToRun]Q814078 /Q:A /R:NQ816093 /Q /O /N /ZQ823182 /Q /O /N /ZQ824105 /Q /O /N /ZQ824141 /Q /O /N /ZQ825119 /Q /O /N /ZQ826939 /Q /O /N /ZWMP9MM2.EXEQ828026 /Q /O /N /ZQ828035 /Q /O /N /ZQ828741 /Q /O /N /ZQ831167 /Q:A /R:NQ832894 /Q:A /R:NQ835732 /Q /O /N /ZQ837001 /Q /O /N /ZQ837009 /Q:A /R:NQ840374 /Q /O /N /Zqchain.exeDX9NTopk.exe
Alanoll Posted June 7, 2004 Posted June 7, 2004 search before hand. I know this one off the top of my head.it's QCHAIN.EXERun it in a normal windows environment, it will give you the prompt. Tell it a folder you know where it is, go to it afterwards, and there is the REAL QCHAIN.EXE. Replace the original
brian873 Posted June 7, 2004 Author Posted June 7, 2004 THANKS for that I knew it would be a simple thing to fix. Just did not know what hotfix it was coming from.Hail Hail
