DTS56 Posted May 27, 2004 Posted May 27, 2004 Hi all,I hope someone can help me.I am in the process of making a multi-boot cd with various tools on it. In both the ISO (using VirtualPC) and when burnt to a cd the cd boots fine then hangs saying "Starting".As far as I am aware, I have followed the same steps to put NTFSDOS on the cd as I did for the other items.I have added several things (successfully) both before and after adding NTFSDOS, but just to make sure I created the 2.88Mb image again and then made a new ISO using the new copy. I still have the same problem.I'm using WinImage 6.1 to extract the image from the floppy disks and Nero 5.5 to make the ISO and burn the cd.Grateful for any light you might be able to shed on this.Thanks in advance.Regards.DTS
Sie Tjin Kian Posted May 27, 2004 Posted May 27, 2004 hi,i had the same problem with partition magic - but it was no problem.burn a cdrw and try to start your real pc with this one. in my case it does all right. i don't know why, but virtual pcs seems to have problems with some bootable iso images and there emulation for floppies.best greez, Sie Tjin Kian
DTS56 Posted May 27, 2004 Author Posted May 27, 2004 Thanks for reply but I have already tried that and still got the same problem when booting the computer from the cd.Sorry I did not make it clear in the first post.many thanks,DTS56
