Professor Frink Posted April 8, 2004 Posted April 8, 2004 I have used the Custom Installation Wizard to tweak my Office XP package, including using the Profile Tool. But one thing keeps happening -- after the install is done, I log onto the domain and open Outlook. But if I look at the properties of the Contacts folder and go to the "Outlook Address Book" tab, the "Show this folder" box is not only unchecked, it is greyed out!I actually found out how to fix it manually:http://www.york.ac.uk/services/cserv/help/...addressbook.htmI go to "Tools", "E-mail Accounts", "Add a new directory or address book", "Additional Address Books", "Outlook Address Book". After I restart Outlook, the Contacts folder is set up right:The problem is, I really don't want to do that every time a new user logs on! Is there some way to set that up in my unattended installation? And if that can't be done, is there a way to simplify it, like with a BAT file or Group Policy?
