mmr55 Posted February 8, 2011 Posted February 8, 2011 I've checked the MS site for an answer and was led to this link: http://support.microsoft.com/kb/956514 In the email received from MS there's a password to open the downloaded hotfix. It doesn't work.Any idea of how I can fix this problem as I need the fonts for projects I'm doing.Thanks
GrofLuigi Posted February 8, 2011 Posted February 8, 2011 I've checked the MS site for an answer and was led to this link: http://support.microsoft.com/kb/956514 In the email received from MS there's a password to open the downloaded hotfix. It doesn't work.Any idea of how I can fix this problem as I need the fonts for projects I'm doing.ThanksIf the file you received is .zip, enter the password you received when the unpacker asks you to. I use WinRar, don't know how others behave. Or you could download it from here.Then, you need to unpack the .exe with parameter /x or -x (sorry, I forgot the exact parameter). I use Universal Extractor for that.Than you need to apply Universal Extractor again to the .msp file. You will get the .ttf files and you install them normally. If they don't want to install, I'd find a way to forcefully replace them in Windows/Fonts and just open that folder in Explorer.If you have Office 2007 installed, you just install the .msp or .exe.GL
