when i installed my previous copy of unattened windows its cool but after i extracted the cd content
and then i just added new theme and created the iso again thats all no big deal
but the new copy with the new theme is
when i run IE7 some times when i press over link the page doesn't open just nothing happen just nothing i got this problem in my browser plz if anyone know the reason tell me
and how to fix it via registry ,,,so i can add the reg fixed line to my $OEM$ to make new copy of this windows
From your other thread(s) I know you`re NOT workink with nLite.
So you got to tell us how IE7 went into your XP - it`s not included by default.
Was it slipstreamed by some method, or was it installed later on running system?
Do you use WindowsUpdate, are all Hotfixes used/installed?
no no look i will explain this version of xp that has IE7 is already Nlited be4 but just 1 time i dont want to edit it again with nlite
the windows after nlite was so good really but now when i just edit the theme inside the $$ folder only and the winint file
and make the iso again with cd-image the IE7 problem appear although i didn't touch anything else just the theme and created the iso again :S
