September 24, 200718 yr Hi,My work has now moved vendor for its hardware. The problem I have is that now we have two types of hardware my OSD image requires updating.Everything works fine other that an issue with the USB Root Hub - Power Management Settings.What I was hoping for is a reg setting to disbale the "USB Root Hub - Power Management Settings - allow the computer to turn off this device to save power" option. i.e uncheck this box.I would then be able to apply this as reg fix as a post install through OSD , so it shouldn't matter on the make of machine / hardware type.Thanks in advanceZorg
