A Few Problems Autoit, Running with Nlite & Deamon CD Changes.
Good Day,
Thanks for looking:
My Problem:
I currently have the following problems:
I would like to
1. Unattended Windows XP SP2, Install - I can do this!
2. Create AutoIt Scripts to do the following (* means i have created the script)
Now the bits i am having problems with:
3. Automatically run these scripts once the Install is finished. -- from the same DVD? is this possible?
4. Then I want to Place another DVD in the drive to install my games, with i would like to auto install them, automount the images in demon tools, and autochange discs etc,, one after the other placing the serial numbers as they go.
Windows XP pro SP2
I want to install the following Second on Same Disk
CdburnerXP (*)
Adobe Reader (*)
OpenOffice
7ZIP (*)
Filezilla (*)
Works 7 (*)
Demon Tools (*)
New Disc AutoRun a Autoit Script to run the scripts for
Generals: Zero Hour
Generals:
Warcraft 3
Warcraft 3: TFT
BattleField 1942
All i really need is some guide with the code for auto running these once the unattended install is finished. and instructions on mounting and changing a cd etc ad continueing.
I have searched but there is so much information some doesnt seem releavent i would really appricate the help
Thanks
TLC
Ok i am continuing to browse the forums, as i learn more each look anyway.
I Now know i can run the exe files via a (Batch) file.
ie.
Echo.
Echo Installing 7 Zip
Echo Please Wait.....
Start /wait 7zip.exe
Echo.
Echo Installing Works 7.0
Start /wait Works.exe
So to finish integrating with XP pro.
I need File structure help. to add the files and the batch file and how to reference the batch file in the run once part.
Not sure about this part.
Also need to know if it is possible to do the automatic mounting of cds and emulation on deamon tools saves me manually saving discs.
I will keep looking but all help is really appricated.
Right I am still totally lost on this but its now 1AM so i am going to get some shut eye.
I don't mind if you direct me to posts etc, if you can't explain but starting to think this can not be done :-(
