benga Posted November 21, 2006 Posted November 21, 2006 Hello allI'm having major problems with an external USB hard disk drive.the device works fine ( tested on other computers, PnP, no driver included or necessary), and which does appear in XP's device manager. However it is unaccessable, unformatable, and doesn't appear in "my computer".what happens during install is as follows : device is recognized, "new device detected : volume", but i then get an error message saying that "windows was unable to load the volume installer, contact vendor for more info".I then get a "your device is correctly installed".this is the setupapi log i get, in french, so i'll add a translation under each entry[2006/11/21 11:20:00 2560.2]#-199 Exécution de "C:\WINDOWS\system32\rundll32.exe" avec la ligne de commande : rundll32.exe newdev.dll,ClientSideInstall \\.\pipe\PNP_Device_Install_Pipe_0.{82C33746-952B-4267-898C-ABA018D273F8}executing of"C:\WINDOWS\system32\rundll32.exe" with command line : rundll32.exe newdev.dll,ClientSideInstall \\.\pipe\PNP_Device_Install_Pipe_0.{82C33746-952B-4267-898C-ABA018D273F8}#I060 Pilote sélectionné défini.Selected driver defined#-019 Recherche de la (des) ID du matériel : storage\volumesearching for device ID : storage/volume#I022 "STORAGE\Volume" a été trouvé dans "C:\WINDOWS\inf\volume.inf"; périphérique : "Volume générique"; pilote : "Volume générique"; fournisseur : "Microsoft"; Mfg : "Microsoft"; Nom de Section: "volume_install".#I022 "STORAGE\Volume" found in "C:\WINDOWS\inf\volume.inf"; device : "generic Volume "; driver : "Generic Volume "; from : "Microsoft"; Mfg : "Microsoft"; Section Name : "volume_install".#I023 Section d'installation réelle: volume_install.Rang : 0x00000000. Date effective du pilote : 07/01/2001.real installation section : volume_install.Rang : 0x00000000. Driver date : 07/01/2001.#-147 Chargement du module installateur de classe pour "Volumes de stockage".Loading class installer module for "Storage Volume"#E360 Un fichier "C:\WINDOWS\system32\syssetup.dll" non signé ou incorrectement signé pour le pilote "Volumes de stockage" sera installé (Stratégie = ignorer). Erreur 0x800b0100: Il n'y avait pas de signature dans le sujet.A file "C:\WINDOWS\system32\syssetup.dll" non signed or incorrectly signed for driver "Storage volumes" will be installed (Strategy = ignore). Error 0x800b0100: No signature in the subject.#E144 Le chargement du module "C:\WINDOWS\system32\syssetup.dll" a échoué. Erreur 126: Le module spécifié est introuvable.Windows n'a pas pu charger l'installateur pour Volume. Contactez le revendeur de votre matériel pour obtenir de l'aide. Erreur 126: Le module spécifié est introuvable.#E144 Loading module "C:\WINDOWS\system32\syssetup.dll" has failed. Errorr 126: Specified module not found.Windows could not load the Volume installer. Contact device vendor for assistance. Error 126 : specified module not found.#I060 Pilote sélectionné défini.Select driver defined#-147 Chargement du module installateur de classe pour "Volumes de stockage".Loading class installer module for "Storage Volumes"#E360 Un fichier "C:\WINDOWS\system32\syssetup.dll" non signé ou incorrectement signé pour le pilote "Volumes de stockage" sera installé (Stratégie = ignorer). Erreur 0x800b0100: Il n'y avait pas de signature dans le sujet.A file "C:\WINDOWS\system32\syssetup.dll" non signed or incorrectly signed for driver "Storage volumes" will be installed (Strategy = ignore). Error 0x800b0100: No signature in the subject.#E144 Le chargement du module "C:\WINDOWS\system32\syssetup.dll" a échoué. Erreur 126: Le module spécifié est introuvable.Loading module "C:\WINDOWS\system32\syssetup.dll" failed. Error 126: Specified module not found.#E161 Le traitement de l'appel à l'installateur de classe a échoué. Erreur 0xe000020d: L'entrée de Registre de l'installateur de classe n'est pas valide.Treatment of class installer call failed : Error 0xe000020d: Non valid class installer Registry entry.-----I really don't know what to do. I tried downloading a new syssetup.dll and placing it in the system32 folder, and i've been browsing for ideas and possible solutions, but not luck.could anyone help me out on this one ?thanks in advance.ben
