new_user Posted August 25, 2005 Posted August 25, 2005 (edited) Hi all !i'v searched a long time for a utility witch assigns my HD partition, CD-ROM and DVD-ROM drive letters automatically for my UA CD.And i would like to pass my experiences here, because i learned a lot here !Thank You all !For me, the "ultimative" drive letter assigment script is MapdriveMapdrive a batch file with explanation, simply to use and multilingual !Made in France And here the link: Mapdrive Mdes !Congratulation and greetings from:new_user (Germany)In France:Longue vie à Mdes, à Mapdrive et à la France Edited August 25, 2005 by new_user
drscouse Posted August 27, 2005 Posted August 27, 2005 (edited) Nice one - cheers...!!!Tharts a huge script... sure I did this with a simple batch file, few lines of text and diskpart.exe... seems way too complicated...Its good to keep things simple....DISKPART> select volume 0Volume 0 is the selected volume.DISKPART> assign letter=xDiskPart successfully assigned the drive letter or mount point.Drives/partitions will usually be the same volume id, and can be found by running diskpart.exe and "list volume" command.. once you know the volume id, it is as easy as "assign letter=" to reassing a letter to the desired volume...For exammple, volume 0, is usually an optical drive, and in the above instance, will be reassigned the letter X. The above is done fromt he command prompt, but can be easily replicated in a very simple script file, consisting of onyly a few lines... Edited August 27, 2005 by drscouse
