November 8, 200421 yr Everyone on office is going crazy because of this problem, we are losing all our important office files.There is no perticular event at which the error pops up it happens anytime even if the person is not typeing the document in word.We have lan at our office and this problem occures only on windows xp machines.following are the error in sequenceERROR 1"There is an unrecovrable disk error on file ~WRL0002The disk you are working on has a media problem that prevents word from useing it.Try the folowing:*Try formatting another disk*Save the documents to another diskERROR 2Word failed reading from this file(~WRL0002).Please restore the network connection or replace the floppy disk and retry.ERROR 3Word has lost data due to a bad network connection or missing floppy.Documents relying on this data are going to be saved and then closed.ERROR 4The document name or path is not valid. Try these suggetions*Check the file permission for the document or drive*Use the file open dialog box to locate the document(D:/My documents-NLA\...\NTPC TANDA.doc)ERROR 5Word has insufficient memory. Do you want to save the "Rescued document 7" as rescued document 8?After the above errors a recued document is created which is useless because when u open it u only see unrecognised characters.What could be the problem?We never disable our lan connections its always on, 4 PC use windows 98 and 3 PC use windows xp and the problem is only with windows xp machine.Please try to help
