shizznats Posted August 17, 2004 Posted August 17, 2004 Hey I have Windows XP SP1 and i want to reinstall my windows and then upgrade to SP2 ... is it ok if i install windows xp pro sp1 with RESET (its a way of cracking xp without putting in any activation code, in safe mode) ... and then will i be able to safely upgrade to SP2? Thanks
prathapml Posted August 17, 2004 Posted August 17, 2004 This is not a "warez" site, and discussion of warez-related items will not be tolerated.Just for your info anyway, let me tell you, upgrading to SP2 will again (so to speak) un-crack all the files that have been cracked, and you need to activate it again. Using RESET 5.02 on a SP2 machine will make the windows installed version break - you can't even login in safe-mode, you need to do a repair install after that. So buying a licensed version of windows is your best option.***Could a mod please lock this thread, or move it out of public discussion please?
