Firewall Problem HELP! :(
I've downloaded TinyXP from torrent, and tried it. so far, it runs blazing fast and smooth, but the thing is, it's outdated, that's why i copied the exact same method the creator used, just to find out that the windows firewall is not working and (maybe) prevents lan games from connecting. windows xp said that the firewall is somewhat removed or unavailable (we could connect to the network though, the lan games are the main problem), and then i tried using the original TinyXP build, and the firewall is also not working, i've triple checked the nlite configuration files, and I know myself, I didn't touch it. Help please, this is the only reason why i'm using untouched version of xp. :(
help please. i'm stuck with this problem
Rule following fail, rule 1.a even. Discussion of warez in relation to a post, even if it isn't the main crux of the discussion, is verboten as per the rules. Sorry mate, banned.
Guest
