donaldsonkd Posted January 10, 2011 Posted January 10, 2011 Using MDT 2010 SP1 on standalone technician machine. Have basics of deploy reference image & capture customized down. Also have basics of deploying a machine for end-user down but can't quite complete the process:Scenario 1: Using auto-logon after the machine is built out, want the TS to use synchronous commands to automatically install our anti-virus and our software deployment client on first login -- problem: the auto-login is using local machine admin account, logs in fine but cannot access domain/network resources to access the distributed file system share to install the AV and software mgmt client.Scenario 2: Disabled auto-logon so that I could just do the first logon manually with an account I know has rights to the network fileshare. THIS method allows the AV and software client to install successfully and I thought all was well until I tried making a tweak change and went to re-run the deployment and kept getting prompt within WinPE indicating that a TS was still in progress. Rebooted to the built image and appears that the TS has indeed NOT completed -- am seeing the "Z:" mapping to the deployment share still in Windows Explorer AND the MININT directory is still present and the log files have not yet populated to C:\windows\temp. Have rebooted AT LEAST a half-dozen times and clearly some process has not been completed to signal the TS that it is finished.Anyone has seen this and/or similar issues and can suggest alternate strategies or where to begin looking?
LinusCaldwell Posted January 14, 2011 Posted January 14, 2011 Scenario 1: Using auto-logon after the machine is built out, want the TS to use synchronous commands to automatically install our anti-virus and our software deployment client on first login -- problem: the auto-login is using local machine admin account, logs in fine but cannot access domain/network resources to access the distributed file system share to install the AV and software mgmt client.You could make the first synchronous command: NET USE \\servername\sharename password /u:DOMAIN\UsernameThat way you can log on with the Administrator account but still have access to domain file shares.
donaldsonkd Posted January 14, 2011 Author Posted January 14, 2011 Thank you for the suggestion! Will try as soon as I can and advise. Most appreciated.
