seskanda Posted July 7, 2010 Posted July 7, 2010 I recall in XP, there was a way to have the battery icon ONLY appear in systray if on battery, and when plugged in, it would, disappear. Can this be done in Vista/7, if so, how? Some help would be great.Thanks in advance.
pankaj Posted November 18, 2010 Posted November 18, 2010 Hi....In Windows 7 you can find ccustomize system tray on the taskbar and select "Turn system icons on or off"
