coucou Posted June 12, 2009 Posted June 12, 2009 Hi,Since I update my WinXP Pro to SP3, all the Auto Updates settings are hiden (grey) see the here bellow image.In fact i want setting the Auto Updates to "Notify for new updates without downloading".I checked the following registery and tested/modify the values tp 0,1,2 without success[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\wuauserv]"Start"=dword:00000002[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Browser]"Start"=dword:00000004[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\BITS]"Start"=dword:00000002[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center]"UpdatesDisableNotify"=dword:00000000[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update]"AUOptions"=dword:00000002"ConfigVer"=dword:00000001TNX for yr helpcoucou
coucou Posted June 12, 2009 Author Posted June 12, 2009 TNX strel for yr help.... unfortunately nothing neww under the sun If you glance at the image above, you'll notice that everything is grey NO SETTING POSIBLE.Regardscoucou
strel Posted June 12, 2009 Posted June 12, 2009 I think this is what you're looking for, and it is in the previous link:...Value name: AUOptionsValue data: 1 to 4 * 1: Keep my computer up to date has been disabled in Automatic Updates....
Geej Posted June 13, 2009 Posted June 13, 2009 Hi,Since I update my WinXP Pro to SP3, all the Auto Updates settings are hiden (grey) see the here bellow image.In fact i want setting the Auto Updates to "Notify for new updates without downloading".I checked the following registery and tested/modify the values tp 0,1,2 without successTry applying only 1 registry tweak (remove the rest) via GUIRUNONCE or RUNONCEEX. (I had mine done this way and it works)[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update]"AUOptions"=dword:00000002
coucou Posted June 14, 2009 Author Posted June 14, 2009 TNX men,tested all and sorry to report you that nothing release the Auto Updates settings.They are still hiden (grey) see image in my first post.Regardscoucou
