b0jengles Posted July 18, 2008 Posted July 18, 2008 (edited) I have been trying and failing to get this scripted install to work with a new Precision t3400 that has a DELL SAS 6/it Integrated controller card with a SAS 15k drive on it. Every time I try and add the drivers to the install it comes back with the following error:The Entry"Dell SAS 6/ir Integrated"in The [sCSI] section of the INF file txtsetup.oemSetup cannot continue.I have tried many different ways to make this work. I hope it is something stupid and simple that I am missing but any help would be greatly appreciated!The current Configuration I have is the followingUsing BDD 2007Used this link to try something different http://www.deployvista.com/Blog/tabid/70/E...18/Default.aspxI have tried with the following file locations of the drivers:%distributionshare%\Operating Systems\WXPSP2\I386\$OEM$\$1\Drivers\SAS6%distributionshare%\Operating Systems\WXPSP2\I386\$OEM$\TEXTMODEAlso tried%distributionshare%\Control\XP32WSAS\$OEM$\$1\DRIVERS\SAS6%distributionshare%\Operating Systems\WP32WSAS\$OEM$\TEXTMODEHere is my unattendfile: I have changed the oempnpdriverpath file location to the corresponding location. I have also deleted the parts that are not needed.[Data] AutoPartition=1 MsDosInitiated="0" UnattendedInstall="Yes"[unattended] UnattendMode = FullUnattended OemSkipEula = Yes OemPreinstall = Yes OemPnPDriversPath = "Drivers\SAS6" TargetPath = \Windows DriverSigningPolicy = Ignore DUDisable = Yes DUStopOnError = No; ExtendOemPartition = 1 ; If Set extends disk partition to end of disk or by x MB; FileSystem = ConvertNTFS ; Specify wheter to leave filesystem alone or convert to NTFS; AutoActivate = No ; Determines if Windows should auto activate over Internet; ActivateProxy = Proxy ; Proxy Setting to use when auto activating windows CrashDumpSetting = 3 ; 3=small memory dump 0-3 DisableDynamicUpdates = Yes ; Don't go get updates from Internet during install Hibernation = Yes ; Yes=Enables hibernation, No=Disabled hibernation WaitForReboot = No ; Yes=Wait 15seconds after guimode setup to reboot; ComputerType = ; Defines Custom HAL type; Factory = Yes ; Used in conjuction with OPK If yes will not delete Sysprep directory; ForceHalDetection = No ; Used in upgrades to keep previous hal; Keyboardlayout = ; Allows specification of keyboard type; NTUpgrade = No ; Indicates whether or not this is an OS upgrade ; OverwriteOEMFilesOnUpgrade = 0 ; Indicates whether OEM files should be overwritten; Repartition = 1 ; Only when booting to CD specify 1 to repartition hard disk; UnattendSwitch = No ; Set to yes during winnt installation to skip welcome; Win9xUpgrade = No ; Indicats if this is an upgrade and to use [Win9xUpg] section[uninstall]; This section has settings to allow an upgraded system to be uninstalled[GuiRunOnce] "cscript.exe %SystemDrive%\MININT\Scripts\LiteTouch.wsf /start"[LicenseFilePrintData] AutoMode=PerSeat ; Licensing Mode usually perseat; AutoUsers=50 ; When in PerServer mode=number of licenses[RegionalSettings]; IF this section is used the Winnt32.exe /copysource:lang setting must be specified; InputLocale_DefaultUser= ; Specifies the Inputlocal and keyboard setting for default user; UserLocale_DefaultUser= ; Locale ID for default User; InputLocale ; Locale\Keyboard combinations to be installed; Language= ; Lanugage locale to be installed; LanguageGroup= ; Language Group to be installed; SystemLocale= ; System Locale to be specified; UserLocale= ; User Locale setting[GuiUnattended]; Arguments= ; Used with Detached programs to provide arguments OEMSkipRegional=1 ; Indicates Regional info GUI to be skipped in setup; EncryptedAdminPassword=No ; For OEMs allows use of hashpwd.exe cannot be used with autologon TimeZone="010" ; Sets Timezone 010=Mountain OemSkipWelcome=1 ; Used to skip welcome screens in GUI setup; ProfilesDir="" ; Allows to change default location of profiles AutoLogon="Yes" ; Indicates that system should autologon after reboot AutoLogonCount=999 ; Number of times to auto logon; DetachedProgram="" ; Specifies programs to run concurrently with Setup AdminPassword="<omitted>[identification] JoinWorkgroup=WORKGROUP; CreateComputerAccountInDomain=Yes; JoinDomain="CONTOSO"; MachineObjectOU= "OU=Workstations, dc=contoso, dc=com"; DomainAdmin="Contoso\Administrator"; DomainAdminPassword="password"[userData] ComputerName=* FullName="<omitted>" OrgName="<omitted>" ProductKey="<omitted>"[Display] BitsPerPel=16 ; Number of colors in display Xresolution=1024 ; X resolution typically 1024 YResolution=768 ; Y resolution typically 768 Vrefresh=60 ; Vertical refresh rate[MassStorageDrivers]; Used when custom disk drivers must be specified; Enter the description name =Retail or OEM"LSI PCI Fusion-MPT Driver Install Disk" = OEM"LSI Adapter, 2Gb FC, models 44929, G2 with 929" = OEM"LSI Adapter, 2Gb FC, models 40919 with 919" = OEM"LSI Adapter, 2Gb FC, models 7202,7402 with 929X" = OEM"LSI Adapter, 2Gb FC, models 7102 with 919X" = OEM"LSI Adapter, Ultra320 SCSI 2000 series, w/1020/1030" = OEM"LSI Adapter, Ultra320 SCSI RAID series, w/1035" = OEM"LSI Adapter, SAS 3000 series, 4-port with 1064" = OEM"LSI Adapter, SAS 3000 series, 8-port with 1068" = OEM"LSI Adapter, SAS 3000 series, 8-port with 1068E" = OEM"LSI Adapter, SAS 3000 series, 4-port with 1064E" = OEM"LSI Adapter, 4Gb FC, models 7104,7204,7404 with 949X" = OEM"LSI Adapter, 4Gb FC, models 7104,7204,7404 with 949E" = OEM"LSI Adapter, SAS RAID-on-Chip, 8-port with 1078" = OEM"Dell SAS 5/E Adapter" = OEM"Dell SAS 5/i Adapter" = OEM"Dell SAS 5/i Integrated" = OEM"Dell SAS 5/iR Integrated D/C" = OEM"Dell SAS 5/iR Integrated Emb" = OEM"Dell SAS 5/iR Adapter" = OEM"Dell SAS 6/iR Adapter" = OEM"Dell SAS 6/iR Integrated" = OEM"Dell SAS 6/iR Integrated" = OEM"Dell SAS 6/iR Integrated" = OEM[OEMBootFiles]; This section is used to specify custom HALs, and also maps to the Mass Storage Device sectionlsipseud.inftxtsetup.oemsymmpi.syssymmpi.infmpixp32.cat[OsChooser]; Used by RIS Clients Only[Here is the symmpi.ini file;; SYMMPI.INF - version XP.10 (Windows XP);; This is the INF file for Windows XP for the SYMMPI based PCI MPI; environment;; ********************************************************************; *; Copyright 2007 LSI Corporation, Inc. All rights reserved. *; *; This file is property of LSI Corporation, Inc. and is licensed *; for use as is. The receipt of or possession of this file does *; convey any rights to modify its contents, in whole, or in part, *; without the specific written consent of LSI Corporation. *; *; ********************************************************************[version]signature="$Windows NT$"Class=SCSIAdapterClassGUID={4D36E97B-E325-11CE-BFC1-08002BE10318}Provider=%LSI%DriverVer=11/20/2007,1.26.05.00CatalogFile.ntx86=mpixp32.cat[DestinationDirs]DefaultDestDir = 12 ; DIRID_DRIVERS[sourceDisksFiles.x86]symmpi.sys = 1lsipseud.inf = 1[sourceDisksNames]1 = %DiskDesc%,,[Manufacturer]%LSI%=LSI%DELL%=DELL[LSI]%DevDesc2% = SYMMPI_Inst, PCI\VEN_1000&DEV_0622%DevDesc3% = SYMMPI_Inst, PCI\VEN_1000&DEV_0624%DevDesc4% = SYMMPI_Inst, PCI\VEN_1000&DEV_0626%DevDesc5% = SYMMPI_Inst, PCI\VEN_1000&DEV_0628%DevDesc6% = SYMMPI_Inst, PCI\VEN_1000&DEV_0030%DevDesc7% = SYMMPI_Inst, PCI\VEN_1000&DEV_0032%DevDesc8% = SYMMPI_Inst, PCI\VEN_1000&DEV_0050%DevDesc9% = SYMMPI_Inst, PCI\VEN_1000&DEV_0054%DevDesc10% = SYMMPI_Inst, PCI\VEN_1000&DEV_0058%DevDesc11% = SYMMPI_Inst, PCI\VEN_1000&DEV_0056%DevDesc12% = SYMMPI_Inst, PCI\VEN_1000&DEV_0640%DevDesc13% = SYMMPI_Inst, PCI\VEN_1000&DEV_0646%DevDesc14% = SYMMPI_Inst, PCI\VEN_1000&DEV_0062[DELL]%DevDescD1% = SYMMPI_Inst, PCI\VEN_1000&DEV_0054&SUBSYS_1F041028%DevDescD2% = SYMMPI_Inst, PCI\VEN_1000&DEV_0054&SUBSYS_1F051028%DevDescD3% = SYMMPI_Inst, PCI\VEN_1000&DEV_0054&SUBSYS_1F061028%DevDescD4% = SYMMPI_Inst, PCI\VEN_1000&DEV_0054&SUBSYS_1F071028%DevDescD5% = SYMMPI_Inst, PCI\VEN_1000&DEV_0054&SUBSYS_1F081028%DevDescD6% = SYMMPI_Inst, PCI\VEN_1000&DEV_0054&SUBSYS_1F091028%DevDescD7% = SYMMPI_Inst, PCI\VEN_1000&DEV_0058&SUBSYS_1F0E1028%DevDescD8% = SYMMPI_Inst, PCI\VEN_1000&DEV_0058&SUBSYS_1F0F1028%DevDescD9% = SYMMPI_Inst, PCI\VEN_1000&DEV_0058&SUBSYS_1F101028%DevDescD10% = SYMMPI_Inst, PCI\VEN_1000&DEV_0058&SUBSYS_021D1028[ControlFlags]ExcludeFromSelect = *[sYMMPI_Inst]CopyFiles = SYMMPI_CopyFilesAddReg = SYMMPI_AddRegCopyINF = lsipseud.inf[sYMMPI_Inst.HW]AddReg = Shutdown_addregDelReg = LegacyScsiportValues[sYMMPI_Inst.Services]AddService = SYMMPI, %SPSVCINST_ASSOCSERVICE%, SYMMPI_Service_Inst, Miniport_EventLog_Inst[sYMMPI_Service_Inst]ServiceType = %SERVICE_KERNEL_DRIVER%StartType = %SERVICE_BOOT_START%ErrorControl = %SERVICE_ERROR_NORMAL%ServiceBinary = %12%\symmpi.sysLoadOrderGroup = SCSI MiniportAddReg = pnpsafe_pci_addregAddReg = bus_type_scsi[sYMMPI_CopyFiles]symmpi.sys,,,1[sYMMPI_AddReg]HKLM,SYSTEM\CurrentControlSet\Services\Symmpi\Parameters\Device,DriverParameter,0x00000002,"EnablePseudoDevice=1;"HKLM,SYSTEM\CurrentControlSet\Services\Symmpi\Parameters\Device,MaximumSGList,0x00010001,0xFFHKLM,SYSTEM\CurrentControlSet\Services\Symmpi\Parameters\Device,NumberOfRequests,0x00010001,0xFF[shutdown_addreg]HKR,"ScsiPort","NeedsSystemShutdownNotification",0x00010001,1[LegacyScsiportValues]HKR,Scsiport,BusNumberHKR,Scsiport,LegacyInterfaceTypeHKR,Scsiport,SlotNumber[pnpsafe_pci_addreg]HKR, "Parameters\PnpInterface", "5", 0x00010001, 0x00000001[bus_type_scsi]HKR, "Parameters", "BusType", 0x00010001, 0x00000001[Miniport_EventLog_Inst]AddReg = Miniport_EventLog_AddReg[Miniport_EventLog_AddReg]HKR,,EventMessageFile,%REG_EXPAND_SZ%,"%%SystemRoot%%\System32\IoLogMsg.dll"HKR,,TypesSupported,%REG_DWORD%,7[strings]LSI = "LSI Corporation"DELL = "Dell Inc."DiskDesc = "LSI PCI Fusion-MPT Driver Install Disk"DevDesc2 = "LSI Adapter, 2Gb FC, models 44929, G2 with 929"DevDesc3 = "LSI Adapter, 2Gb FC, models 40919 with 919"DevDesc4 = "LSI Adapter, 2Gb FC, models 7202,7402 with 929X"DevDesc5 = "LSI Adapter, 2Gb FC, models 7102 with 919X"DevDesc6 = "LSI Adapter, Ultra320 SCSI 2000 series, w/1020/1030"DevDesc7 = "LSI Adapter, Ultra320 SCSI RAID series, w/1035"DevDesc8 = "LSI Adapter, SAS 3000 series, 4-port with 1064"DevDesc9 = "LSI Adapter, SAS 3000 series, 8-port with 1068"DevDesc10 = "LSI Adapter, SAS 3000 series, 8-port with 1068E"DevDesc11 = "LSI Adapter, SAS 3000 series, 4-port with 1064E"DevDesc12 = "LSI Adapter, 4Gb FC, models 7104,7204,7404 with 949X"DevDesc13 = "LSI Adapter, 4Gb FC, models 7104,7204,7404 with 949E"DevDesc14 = "LSI Adapter, SAS RAID-on-Chip, 8-port with 1078"DevDescD1 = "Dell SAS 5/E Adapter"DevDescD2 = "Dell SAS 5/i Adapter"DevDescD3 = "Dell SAS 5/i Integrated"DevDescD4 = "Dell SAS 5/iR Integrated D/C"DevDescD5 = "Dell SAS 5/iR Integrated Emb"DevDescD6 = "Dell SAS 5/iR Adapter"DevDescD7 = "Dell SAS 6/iR Adapter"DevDescD8 = "Dell SAS 6/iR Integrated"DevDescD9 = "Dell SAS 6/iR Integrated"DevDescD10 = "Dell SAS 6/iR Integrated";*******************************************;Handy macro substitutions (non-localizable)SPSVCINST_ASSOCSERVICE = 0x00000002SERVICE_KERNEL_DRIVER = 1SERVICE_BOOT_START = 0SERVICE_ERROR_NORMAL = 1REG_EXPAND_SZ = 0x00020000REG_DWORD = 0x00010001here is the txtsetup.oem# txtsetup.oem - version XP.9 - SYMMPI Windows XP x86 driver## ***********************************************************************# *# Copyright 2007 LSI Corporation. All rights reserved. *# *# This file is property of LSI Corporation. and is licensed for *# use as is. The receipt of or posession of this file does not *# convey any rights to modify its contents, in whole, or in part, *# without the specific written consent of LSI Corporation. *# *# ***********************************************************************## format for txtsetup.oem.## General format:## [section]# key = value1,value2,...### The hash ('#') introduces a comment.# Strings with embedded spaces, commas, or hashes should be double-quoted#[Disks]# This section lists all disks in the disk set.## <description> is a descriptive name for a disk, used when# prompting for the disk# <tagfile> is a file whose presence allows setup to recognize# that the disk is inserted.# <directory> is where the files are located on the disk.#d1 = "LSI PCI Fusion-MPT Miniport Driver",\symmpi.tag,\[Defaults]# This section lists the default selection for each 'required'# hardware component. If a line is not present for a component,# the default defaults to the first item in the [<component_name>]# section (see below).## <component_name> is one of computer, display, keyboard, mouse, scsi# <id> is a unique <within the component> string to be associated# with an option.scsi = SYMMPI_32[scsi]# This section lists the options available for a particular component.## <id> is the unique string for the option# <description> is a text string, presented to the user in a menu# <key_name> gives the name of the key to be created for the component in# HKEY_LOCAL_MACHINE\ControlSet001\ServicesSYMMPI_32 = "LSI PCI Fusion-MPT Driver (XP 32-bit)",symmpi[HardwareIds.scsi.SYMMPI_32]id = "PCI\VEN_1000&DEV_0622", "symmpi"id = "PCI\VEN_1000&DEV_0624", "symmpi"id = "PCI\VEN_1000&DEV_0626", "symmpi"id = "PCI\VEN_1000&DEV_0628", "symmpi"id = "PCI\VEN_1000&DEV_0030", "symmpi"id = "PCI\VEN_1000&DEV_0032", "symmpi"id = "PCI\VEN_1000&DEV_0050", "symmpi"id = "PCI\VEN_1000&DEV_0054", "symmpi"id = "PCI\VEN_1000&DEV_0058", "symmpi"id = "PCI\VEN_1000&DEV_005E", "symmpi"id = "PCI\VEN_1000&DEV_0056", "symmpi"id = "PCI\VEN_1000&DEV_005A", "symmpi"id = "PCI\VEN_1000&DEV_0640", "symmpi"id = "PCI\VEN_1000&DEV_0646", "symmpi"id = "PCI\VEN_1000&DEV_0062", "symmpi"# This section lists the files that should be copied if the user# selects a particular component option.## <file_type> is one of driver, port, class, dll, hal, inf, or detect.# See below.# <source_disk> identifies where the file is to be copied from, and must# match en entry in the [Disks] section.# <filename> is the name of the file. This will be appended to the# directory specified for the disk in the [Disks] section to form the# full path of the file on the disk.[Files.scsi.SYMMPI_32]driver = d1,symmpi.sys,SYMMPIinf = d1,symmpi.infinf = d1,lsipseud.infcatalog = d1,mpixp32.cat[Config.SYMMPI]# This section specifies values to be set in the registry for# particular component options. Required values in the services\xxx# key are created automatically -- use this section to specify additional# keys to be created in services\xxx and values in services\xxx and# services\xxx\yyy.## <key_name> is relative to the services node for this device.# If it is empty, then it refers to the services node.# If specified, the key is created first.# <value_name> specifies the value to be set within the key# <value_type> is a string like REG_DWORD. See below.# <value> specifies the actual value; its format depends on <value_type>value = Parameters\PnpInterface,5,REG_DWORD,1 Edited July 18, 2008 by b0jengles
cdob Posted July 19, 2008 Posted July 19, 2008 The Entry"Dell SAS 6/ir Integrated"in The [sCSI] section of the INF file txtsetup.oemSetup cannot continue.Setting is missing at txtsetup.oem [sCSI] section.File symmpi.inf is not used that early.[scsi]# This section lists the options available for a particular component.## <id> is the unique string for the option# <description> is a text string, presented to the user in a menu# <key_name> gives the name of the key to be created for the component in# HKEY_LOCAL_MACHINE\ControlSet001\ServicesSYMMPI_32 = "LSI PCI Fusion-MPT Driver (XP 32-bit)",symmpiTry one single line at [MassStorageDrivers] section[MassStorageDrivers]; Used when custom disk drivers must be specified; Enter the description name =Retail or OEM"LSI PCI Fusion-MPT Driver (XP 32-bit)" = OEMNo need to add txtsetup.oem to [OEMBootFiles].Try[OEMBootFiles]; This section is used to specify custom HALs, and also maps to the Mass Storage Device sectionlsipseud.infsymmpi.syssymmpi.infmpixp32.cat
b0jengles Posted July 21, 2008 Author Posted July 21, 2008 So I have tried so many different ways from different sites I may need a little clarification.Do I need to include a Cab file(created from the symmpi.sys file) in the windows source / i386 folder? Also do I need to include the driver info in the TXTSETUP.SIF file in the i386 folder? Or do I just create a folder structure of "Windows Source / I386 /$OEM/ TEXTMODE/"MY Driver Files""and "Windows Source / I386 /$OEM/$1/DRIVERS/SAS6/ "MY Driver Files""Then edit the unattend.txt with your corresponding edits?
cdob Posted July 21, 2008 Posted July 21, 2008 So I have tried so many different ways from different sites I may need a little clarification.Actually there are different approaches and different solutions.How do you like to install windows? Local installation from CD or RIS installation are different cases.Do I need to include a Cab file(created from the symmpi.sys file) in the windows source / i386 folder?No, you don't have to include a cab file to I386\.Also do I need to include the driver info in the TXTSETUP.SIF file in the i386 folder?No, don't edit txtsetup.sif. Editing txtsetup.sif is another approach.That's a fine solution too.Or do I just create a folder structure of "Windows Source / I386 /$OEM/ TEXTMODE/"MY Driver Files""and "Windows Source / I386 /$OEM/$1/DRIVERS/SAS6/ "MY Driver Files""Then edit the unattend.txt with your corresponding edits?Well mentioned example use a strange solution.[MassStorageDrivers] [OEMBootFiles] sould copy file already.No need to use OemPnPDriversPath. However example should work too.Some other examples:http://support.microsoft.com/kb/288344/http://support.microsoft.com/kb/816299/http://support.microsoft.com/kb/289707/This copy files twice:\I386\$OEM$\I386\$OEM$\TEXTMODEThis dosn't match CD installation.Find a solution matching your windows installation method.
b0jengles Posted July 21, 2008 Author Posted July 21, 2008 http://support.microsoft.com/kb/816299/Fixed the issue.Seems as though yea I was using more then one way of doing it and it was having conflicts.Thanks for all the help
