Hi all,
I've been successfully using RIS to deploy images to my laptops and desktops for some time now (few years). Just recently, within the last few months, I am unable to image new models AND some of the older ones. I suspect this happened around the same time that I added new NIC drivers to the I386 directory.
I've tested adding new NIC drivers for different NIC's all together and I cannot get it to deploy the image, it keeps coming up with... "The Operating System... blah blah blah, doesn't have the necessary driver to blah blah blah.
In looking in the event logs, I am not getting a lot of these "information" events...
Event Type: Information
Event Source: BINLSVC
Event Category: None
Event ID: 1004
Date: 10/1/2007
Time: 1:41:43 PM
User: N/A
Computer: HQSVR01RIS
Description:
The description for Event ID ( 1004 ) in Source ( BINLSVC ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: HQ0018, %user%.
This particular case, the image was pushed to the laptop. Here is another "information" event where it says the same thing but didn't work.
Event ID: 1004
Date: 10/1/2007
Time: 10:50:09 AM
User: N/A
Description:
The description for Event ID ( 1004 ) in Source ( BINLSVC ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: HQDT20035, %user%.
Any help would be appreciated, I can't image new machines so I'm stuck unless I want to do them all manually.
Thanks,
Chris
