morland Posted August 10, 2007 Posted August 10, 2007 Hi,Can you please help. I am having one too many problems with IE7.1) Have already defined a default start page but despite this, everytime I start IE, it starts with a page having URL "http://runonce.msn.com/runonce2.aspx". But NOTHING happens on this page2) In Gmail when I try to switch from basic HTML mode to standard mode, I just get a page with URL "http://mail.google.com/mail/". Here too nothing happens and looks like I am forced to live with using Gmail only in simple HTML mode 3) Nothing which appears to have a javascript window or a download activity is not working. I have tried many websites including the one from where I was trying to download the Intel's chipset utility, but no download happens...Have tried refresh, starting all over again etc. etc. but Nothing4) Have tried to reset all IE settings to default but still no solutionWill appreciate your help.Thanks.
cluberti Posted August 10, 2007 Posted August 10, 2007 What happens if you reinstall the Windows Script Host 5.6 package? You can get it from www.microsoft.com/downloads.
morland Posted August 10, 2007 Author Posted August 10, 2007 What happens if you reinstall the Windows Script Host 5.6 package? You can get it from www.microsoft.com/downloads.Thanks for the reply. I went to the URL but could not find the "Windows Script Host 5.6 package" despite doing a search and using the entire thing as the keywords to search. Can you please guide what I need to select for the following options in order to get the desired file:Keywords Product/TechnologyCategoryMuch advance thanks for your further help.
cluberti Posted August 10, 2007 Posted August 10, 2007 That'd be because 5.7 was just released, and I had no idea... :http://www.microsoft.com/downloads/details...;DisplayLang=en
morland Posted August 11, 2007 Author Posted August 11, 2007 Thanks for the reply cluberti. Appreciate it I have just downloaded the file... Am about to run it...let's see what happens
morland Posted August 11, 2007 Author Posted August 11, 2007 Hi Cluberti.You are an angel I downloaded and installed the Windows Script Host 5.7 package and all my problems related to IE 7 have vanished ..Thank you sooooo much.Regards.
