BattlePanic Posted August 4, 2007 Posted August 4, 2007 I'm setting up a network with three keyboardless touchscreen terminals each running Windows 2000 and logging onto a Windows 2000 Server. Each terminal will be using a common roaming, mandatory profile located on a network share so that a consistent user profile will be maintained across the three workstations. As these workstations will not have keyboards, I would like for them to log onto the domain automatically.I have created a network share and ensured that the appropriate Active Directory user account has it's profile set to point to the network share. I have tested this setup before enabling automatic logon and the workstations appear to load the roaming profile without any problemsI would like to enable automatic logon by setting the appropriate registry keys AutoAdminLogon, DefaultDomainName, DefaultUserName, and DefaultPassword all located in:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\WinlogonUnfortunately once Automatic Logon is enabled the workstations are unable to access the roaming profile and revert to their locally cached profile. During the automated logon the following message is displayed------------------------------------Windows cannot create profile directory \\basement\USER_PROFILES\staff.pds You will be logged on with a local profile only. Chages made to the profile will not be prpagated to the server. Contact your network administrator.Detail - The network path was not found.------------------------------------This is quite puzzling as the logon sequence has no problem accessing the roaming profile if the logon is performed manually with a keyboard.I have examined a userenv.log of both an "automatic logon" which fails to read the roaming profile and a normal logon which loads the roaming profile without any obvious problems. Does anyone have any clues as to why Automatically logging on to a domain would cause problems accessing the roaming user profile?Here are the two userenv.log files. The first is the inaccessible roaming profile and the second one loads the profile successfully but automatic logon is turned off.First the problematic "Automatic Logon"------------------------------------USERENV(9c.78) 22:13:43:128 LibMain: Process Name: \??\C:\WINNT\system32\winlogon.exeUSERENV(d4.d0) 22:13:44:189 LibMain: Process Name: C:\WINNT\system32\services.exeUSERENV(e0.dc) 22:13:44:610 LibMain: Process Name: C:\WINNT\system32\lsass.exeUSERENV(e0.dc) 22:13:45:081 LibMain: Process Name: C:\WINNT\system32\lsass.exeUSERENV(194.198) 22:13:47:083 LibMain: Process Name: C:\WINNT\system32\svchost.exeUSERENV(1e8.1e4) 22:13:47:835 LibMain: Process Name: C:\WINNT\system32\EloSrvce.exeUSERENV(200.224) 22:13:48:145 LibMain: Process Name: C:\WINNT\system32\EloLnchr.exeUSERENV(244.220) 22:13:48:956 LibMain: Process Name: C:\WINNT\system32\MSTask.exeUSERENV(9c.238) 22:13:49:267 ApplyGroupPolicy: Entering. Flags = 7USERENV(9c.238) 22:13:49:287 ProcessGPOs:USERENV(9c.238) 22:13:49:287 ProcessGPOs:USERENV(9c.238) 22:13:49:287 ProcessGPOs: Starting computer Group Policy processing...USERENV(9c.238) 22:13:49:297 ProcessGPOs:USERENV(9c.238) 22:13:49:297 ProcessGPOs:USERENV(9c.238) 22:13:49:297 EnterCriticalPolicySection: Machine critical section has been claimed. Handle = 0x1c0USERENV(9c.238) 22:13:49:297 ProcessGPOs: Machine role is 2.USERENV(9c.238) 22:13:49:307 ProcessGPOs: The DC for domain AUXV is not availableUSERENV(9c.238) 22:13:49:377 LeaveCriticalPolicySection: Critical section 0x1c0 has been released.USERENV(9c.238) 22:13:49:377 ProcessGPOs: Computer Group Policy has been applied.USERENV(9c.238) 22:13:49:387 ProcessGPOs: Leaving with 0.USERENV(9c.238) 22:13:49:387 ApplyGroupPolicy: Leaving successfully.USERENV(9c.254) 22:13:49:837 GPOThread: Next refresh will happen in 108 minutesUSERENV(9c.78) 22:13:50:709 =========================================================USERENV(9c.78) 22:13:50:719 LoadUserProfile: Entering, hToken = <0x21c>, lpProfileInfo = 0x6f648USERENV(9c.78) 22:13:50:719 LoadUserProfile: Entering, hToken = <0x21c>, lpProfileInfo = 0x6f648USERENV(9c.78) 22:13:50:719 LoadUserProfile: lpProfileInfo->dwFlags = <0x0>USERENV(9c.78) 22:13:50:719 LoadUserProfile: lpProfileInfo->lpUserName = <staff>USERENV(9c.78) 22:13:50:719 LoadUserProfile: lpProfileInfo->lpProfilePath = <\\basement\USER_PROFILES\staff>USERENV(9c.78) 22:13:50:779 LoadUserProfile: lpProfileInfo->lpDefaultPath = <\\BASEMENT\netlogon\Default User>USERENV(9c.78) 22:13:50:779 LoadUserProfile: NULL server nameUSERENV(9c.78) 22:13:50:779 GetUserMutex: enteringUSERENV(9c.78) 22:13:50:799 GetUserMutex: Waiting...USERENV(9c.78) 22:13:50:799 GetUserMutex: Wait succeeded. Mutex currently held.USERENV(9c.78) 22:13:50:799 ParseProfilePath: Entering, lpProfilePath = <\\basement\USER_PROFILES\staff>USERENV(9c.78) 22:13:50:799 CheckXForestLogon: checking x-forest logon, user handle = 540USERENV(9c.78) 22:13:50:869 MyGetDomainDNSName: MyGetUserName failed for dns domain name with 1355USERENV(9c.78) 22:13:50:869 CheckUserInMachineForest: MyGetDomainName failed with 1355.USERENV(9c.78) 22:13:50:869 CheckXForestLogon : CheckUserInMachineForest failed with 1355USERENV(9c.78) 22:13:50:869 ParseProfilePath: CheckXForestLogon failed, hr = 8007054BUSERENV(9c.78) 22:13:50:889 ParseProfilePath: Tick Count = 0USERENV(9c.78) 22:13:50:959 PingComputer: PingBufferSize set as 2048USERENV(9c.78) 22:13:50:959 PingComputer: First time: 0USERENV(9c.78) 22:13:50:959 PingComputer: Fast link. Exiting.USERENV(9c.78) 22:13:50:959 ParseProfilePath: FindFirstFile failed with error 53USERENV(9c.78) 22:13:50:959 CreateSecureDirectory: Entering with <\\basement\USER_PROFILES\staff>USERENV(9c.78) 22:13:50:959 CreateNestedDirectory: Failed to create the directory with error 53.USERENV(9c.78) 22:13:50:959 CreateSecureDirectory: Failed to created the directory <\\basement\USER_PROFILES\staff>USERENV(9c.78) 22:13:50:959 ParseProfilePath: Failed to create user sub-directory. Error = 53USERENV(9c.78) 22:13:50:969 ParseProfilePath: Did not create the sub-directory. Generating a new name.USERENV(9c.78) 22:13:50:969 ParseProfilePath: Entering name generating code working with a path of <\\basement\USER_PROFILES\staff>.USERENV(9c.78) 22:13:50:969 ParseProfilePath: FindFirstFile failed with error 53USERENV(9c.78) 22:13:50:969 CreateSecureDirectory: Entering with <\\basement\USER_PROFILES\staff.pds>USERENV(9c.78) 22:13:50:969 CreateNestedDirectory: Failed to create the directory with error 53.USERENV(9c.78) 22:13:50:969 CreateSecureDirectory: Failed to created the directory <\\basement\USER_PROFILES\staff.pds>USERENV(9c.78) 22:13:50:969 ParseProfilePath: Failed to create the sub-directoryUSERENV(1f4.2a8) 22:13:50:979 LibMain: Process Name: C:\WINNT\system32\svchost.exeUSERENV(29c.2a0) 22:13:51:520 LibMain: Process Name: C:\WINNT\system32\svchost.exeUSERENV(1f4.2b4) 22:13:52:862 LibMain: Process Name: C:\WINNT\system32\svchost.exeUSERENV(9c.78) 22:13:55:295 LoadUserProfile: ParseProfilePath returned a directory of <>USERENV(9c.78) 22:13:55:295 RestoreUserProfile: EnteringUSERENV(9c.78) 22:13:55:295 IsCentralProfileReachable: EnteringUSERENV(9c.78) 22:13:55:295 IsCentralProfileReachable: Null path. LeavingUSERENV(9c.78) 22:13:55:305 RestoreUserProfile: Profile path = <>USERENV(9c.78) 22:13:55:305 ExtractProfileFromBackup: A profile already existsUSERENV(9c.78) 22:13:55:305 PatchNewProfileIfRequred: A profile already exists with the current sid, exittingUSERENV(9c.78) 22:13:55:305 CreateLocalProfileKey: Not setting additional SecurityUSERENV(9c.78) 22:13:55:305 GetExistingLocalProfileImage: Found entry in profile list for existing local profileUSERENV(9c.78) 22:13:55:305 GetExistingLocalProfileImage: Local profile image filename = <%SystemDrive%\Documents and Settings\staff>USERENV(9c.78) 22:13:55:305 GetExistingLocalProfileImage: Expanded local profile image filename = <C:\Documents and Settings\staff>USERENV(9c.78) 22:13:55:355 GetExistingLocalProfileImage: No local mandatory profile. Error = 2USERENV(9c.78) 22:13:55:365 GetExistingLocalProfileImage: Found local profile image file ok <C:\Documents and Settings\staff\ntuser.dat>USERENV(9c.78) 22:13:55:365 Local Existing Profile Image is reachableUSERENV(9c.78) 22:13:55:365 Local profile name is <C:\Documents and Settings\staff>USERENV(9c.78) 22:13:55:365 RestoreUserProfile: No central profile. Attempting to load local profile.USERENV(9c.78) 22:13:55:486 MyRegLoadKey: Mutex released. Returning 0.USERENV(9c.78) 22:13:55:716 MyRegLoadKey: Mutex released. Returning 0.USERENV(9c.78) 22:13:55:716 CreateClassHive: existing user classes hive foundUSERENV(9c.78) 22:13:55:716 RestoreUserProfile: About to Leave. Final Information follows:USERENV(9c.78) 22:13:55:716 Profile was successfully loaded.USERENV(9c.78) 22:13:55:716 lpProfile->lpRoamingProfile = <>USERENV(9c.78) 22:13:55:716 lpProfile->lpLocalProfile = <C:\Documents and Settings\staff>USERENV(9c.78) 22:13:55:716 lpProfile->dwInternalFlags = 0x0USERENV(9c.78) 22:13:55:716 RestoreUserProfile: Leaving.USERENV(9c.78) 22:13:55:946 UpgradeProfile: EnteringUSERENV(9c.78) 22:13:55:946 UpgradeProfile: Build numbers matchUSERENV(9c.78) 22:13:55:946 UpgradeProfile: Leaving SuccessfullyUSERENV(9c.78) 22:13:55:946 LoadUserProfile: Releasing mutex.USERENV(9c.78) 22:13:55:966 LoadUserProfile: Leaving with a value of 1.USERENV(9c.78) 22:13:55:966 LoadUserProfile: hProfile = <0x4b4>USERENV(9c.78) 22:13:55:966 =========================================================USERENV(9c.2ac) 22:13:56:157 ApplyGroupPolicy: Entering. Flags = 6USERENV(9c.2ac) 22:13:56:157 ProcessGPOs:USERENV(9c.2ac) 22:13:56:157 ProcessGPOs:USERENV(9c.2ac) 22:13:56:157 ProcessGPOs: Starting user Group Policy processing...USERENV(9c.2ac) 22:13:56:157 ProcessGPOs:USERENV(9c.2ac) 22:13:56:157 ProcessGPOs:USERENV(9c.2ac) 22:13:56:157 EnterCriticalPolicySection: User critical section has been claimed. Handle = 0x4e4USERENV(9c.2ac) 22:13:56:167 ProcessGPOs: Machine role is 2.USERENV(9c.2ac) 22:13:56:167 PingComputer: PingBufferSize set as 2048USERENV(9c.2ac) 22:13:56:177 PingComputer: First time: 0USERENV(9c.2ac) 22:13:56:177 PingComputer: Fast link. Exiting.USERENV(9c.2ac) 22:13:56:177 ProcessGPOs: User name is: CN=staff,OU=Auxv Staff,DC=auxv,DC=com, Domain name is: AUXVUSERENV(9c.2ac) 22:13:56:177 ProcessGPOs: Domain controller is: \\basement.auxv.com Domain DN is auxv.comUSERENV(9c.2ac) 22:13:56:227 MyGetDomainDNSName: Successfully determined fqdn CN=staff,OU=Auxv Staff,DC=auxv,DC=comUSERENV(9c.2ac) 22:13:56:247 MyGetDomainDNSName: Successfully obtained domain dns name auxv.comUSERENV(9c.2ac) 22:13:56:247 ProcessGPOs: Calling GetGPOInfo for normal policy modeUSERENV(9c.2ac) 22:13:56:247 GetGPOInfo: ********************************USERENV(9c.2ac) 22:13:56:247 GetGPOInfo: Entering...USERENV(9c.2ac) 22:13:56:277 GetGPOInfo: Server connection established.USERENV(9c.2ac) 22:13:56:337 GetGPOInfo: Bound successfully.USERENV(9c.2ac) 22:13:56:347 SearchDSObject: Searching <OU=Auxv Staff,DC=auxv,DC=com>USERENV(9c.2ac) 22:13:56:347 SearchDSObject: Found GPO(s): <[LDAP://CN={EA25CBE8-B7DD-42EF-99C0-7055C637F773},CN=Policies,CN=System,DC=auxv,DC=com;1]>USERENV(9c.2ac) 22:13:56:347 SearchDSObject: The link to GPO LDAP://CN={EA25CBE8-B7DD-42EF-99C0-7055C637F773},CN=Policies,CN=System,DC=auxv,DC=com is disabled. It will be skipped.USERENV(9c.2ac) 22:13:56:347 SearchDSObject: Searching <DC=auxv,DC=com>USERENV(9c.2ac) 22:13:56:347 SearchDSObject: Found GPO(s): <[LDAP://CN={31B2F340-016D-11D2-945F-00C04FB984F9},CN=Policies,CN=System,DC=auxv,DC=com;0]>USERENV(9c.2ac) 22:13:56:347 ProcessGPO: ==============================USERENV(9c.2ac) 22:13:56:347 ProcessGPO: Deferring search for <LDAP://CN={31B2F340-016D-11D2-945F-00C04FB984F9},CN=Policies,CN=System,DC=auxv,DC=com>USERENV(9c.2ac) 22:13:56:377 SearchDSObject: Searching <CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=auxv,DC=com>USERENV(9c.2ac) 22:13:56:387 SearchDSObject: No GPO(s) for this object.USERENV(9c.2ac) 22:13:56:387 EvaluateDeferredGPOs: Searching for GPOs in cn=policies,cn=system,DC=auxv,DC=comUSERENV(9c.2ac) 22:13:56:397 ProcessGPO: ==============================USERENV(9c.2ac) 22:13:56:397 ProcessGPO: Searching <CN={31B2F340-016D-11D2-945F-00C04FB984F9},CN=Policies,CN=System,DC=auxv,DC=com>USERENV(9c.2ac) 22:13:56:397 ProcessGPO: User has access to this GPO.USERENV(9c.2ac) 22:13:56:397 ProcessGPO: Found functionality version of: 2USERENV(9c.2ac) 22:13:56:407 ProcessGPO: Found file system path of: <\\auxv.com\sysvol\auxv.com\Policies\{31B2F340-016D-11D2-945F-00C04FB984F9}>USERENV(9c.2ac) 22:13:56:447 ProcessGPO: Found common name of: <{31B2F340-016D-11D2-945F-00C04FB984F9}>USERENV(9c.2ac) 22:13:56:447 ProcessGPO: Found display name of: <Default Domain Policy>USERENV(9c.2ac) 22:13:56:447 ProcessGPO: Found user version of: GPC is 1, GPT is 1USERENV(9c.2ac) 22:13:56:447 ProcessGPO: Found flags of: 0USERENV(9c.2ac) 22:13:56:447 ProcessGPO: Found extensions: [{3060E8D0-7020-11D2-842D-00C04FA372D4}{3060E8CE-7020-11D2-842D-00C04FA372D4}]USERENV(9c.2ac) 22:13:56:447 ProcessGPO: ==============================USERENV(9c.2ac) 22:13:56:497 GetGPOInfo: GPO Local Group Policy doesn't contain any data since the version number is 0. It will be skipped.USERENV(9c.2ac) 22:13:56:497 GetGPOInfo: Leaving with 1USERENV(9c.2ac) 22:13:56:497 GetGPOInfo: ********************************USERENV(9c.2ac) 22:13:56:497 ProcessGPOs: OpenThreadToken failed with error 1008, assuming thread is not impersonatingUSERENV(9c.2ac) 22:13:56:497 ProcessGPOs: -----------------------USERENV(9c.2ac) 22:13:56:497 ProcessGPOs: Processing extension RegistryUSERENV(9c.2ac) 22:13:56:507 CompareGPOLists: The lists are the same.USERENV(9c.2ac) 22:13:56:507 CheckGPOs: No GPO changes and no security group membership change and extension Registry has NoGPOChanges set.USERENV(9c.2ac) 22:13:56:507 ProcessGPOs: -----------------------USERENV(9c.2ac) 22:13:56:507 ProcessGPOs: -----------------------USERENV(9c.2ac) 22:13:56:507 ProcessGPOs: Processing extension Folder RedirectionUSERENV(9c.2ac) 22:13:56:507 CompareGPOLists: The lists are the same.USERENV(9c.2ac) 22:13:56:507 CheckGPOs: No GPO changes but couldn't read extension Folder Redirection's status or policy time.USERENV(9c.2ac) 22:13:56:507 ProcessGPOs: Extension Folder Redirection skipped because both deleted and changed GPO lists are empty.USERENV(9c.2ac) 22:13:56:507 ProcessGPOs: -----------------------USERENV(9c.2ac) 22:13:56:507 ProcessGPOs: Processing extension Microsoft Disk QuotaUSERENV(9c.2ac) 22:13:56:507 ProcessGPOs: Extension Microsoft Disk Quota skipped with flags 0x6.USERENV(9c.2ac) 22:13:56:517 ProcessGPOs: -----------------------USERENV(9c.2ac) 22:13:56:517 ProcessGPOs: Processing extension ScriptsUSERENV(9c.2ac) 22:13:56:517 CompareGPOLists: The lists are the same.USERENV(9c.2ac) 22:13:56:517 CheckGPOs: No GPO changes but couldn't read extension Scripts's status or policy time.USERENV(9c.2ac) 22:13:56:517 ProcessGPOs: Extension Scripts skipped because both deleted and changed GPO lists are empty.USERENV(9c.2ac) 22:13:56:517 ProcessGPOs: -----------------------USERENV(9c.2ac) 22:13:56:517 ProcessGPOs: Processing extension SecurityUSERENV(9c.2ac) 22:13:56:517 ProcessGPOs: Extension Security skipped with flags 0x6.USERENV(9c.2ac) 22:13:56:517 ProcessGPOs: -----------------------USERENV(9c.2ac) 22:13:56:517 ProcessGPOs: Processing extension Internet Explorer BrandingUSERENV(9c.2ac) 22:13:56:517 CompareGPOLists: The lists are the same.USERENV(9c.2ac) 22:13:56:517 CheckGPOs: No GPO changes but couldn't read extension Internet Explorer Branding's status or policy time.USERENV(9c.2ac) 22:13:56:527 ProcessGPOs: Extension Internet Explorer Branding skipped because both deleted and changed GPO lists are empty.USERENV(9c.2ac) 22:13:56:527 ProcessGPOs: -----------------------USERENV(9c.2ac) 22:13:56:527 ProcessGPOs: Processing extension EFS recoveryUSERENV(9c.2ac) 22:13:56:527 ProcessGPOs: Extension EFS recovery skipped with flags 0x6.USERENV(9c.2ac) 22:13:56:527 ProcessGPOs: -----------------------USERENV(9c.2ac) 22:13:56:527 ProcessGPOs: Processing extension Application ManagementUSERENV(9c.2ac) 22:13:56:527 CompareGPOLists: The lists are the same.USERENV(9c.2ac) 22:13:56:527 CheckGPOs: No GPO changes but couldn't read extension Application Management's status or policy time.USERENV(9c.2ac) 22:13:56:527 ProcessGPOs: Extension Application Management skipped because both deleted and changed GPO lists are empty.USERENV(9c.2ac) 22:13:56:527 ProcessGPOs: -----------------------USERENV(9c.2ac) 22:13:56:527 ProcessGPOs: Processing extension IP SecurityUSERENV(9c.2ac) 22:13:56:537 ProcessGPOs: Extension IP Security skipped with flags 0x6.USERENV(9c.2ac) 22:13:56:537 LeaveCriticalPolicySection: Critical section 0x4e4 has been released.USERENV(9c.2ac) 22:13:56:537 ProcessGPOs: User Group Policy has been applied.USERENV(9c.2ac) 22:13:56:537 ProcessGPOs: Leaving with 1.USERENV(9c.2ac) 22:13:56:537 ApplyGroupPolicy: Leaving successfully.USERENV(9c.300) 22:13:56:597 GPOThread: Next refresh will happen in 117 minutesUSERENV(31c.318) 22:13:56:797 LibMain: Process Name: C:\WINNT\system32\userinit.exeUSERENV(d4.144) 22:13:56:858 ImpersonateUser: Failed to impersonate user with 5.USERENV(d4.144) 22:13:56:858 GetUserNameAndDomain Failed to impersonate userUSERENV(320.330) 22:13:57:769 LibMain: Process Name: C:\WINNT\Explorer.EXEUSERENV(34c.348) 22:13:59:441 LibMain: Process Name: C:\WINNT\system32\mobsync.exeUSERENV(37c.378) 22:14:00:052 LibMain: Process Name: C:\WINNT\system32\EloDkMon.exeUSERENV(394.390) 22:14:00:212 LibMain: Process Name: C:\WINNT\system32\EloTTray.exeUSERENV(398.374) 22:14:01:074 LibMain: Process Name: C:\WINNT\system32\mobsync.exeUSERENV(348.34c) 22:14:01:104 LibMain: Process Name: C:\WINNT\system32\EloRtBtn.exeUSERENV(200.228) 22:14:01:194 LibMain: Process Name: C:\WINNT\system32\EloLnchr.exeUSERENV(3b0.3a8) 22:14:06:101 LibMain: Process Name: C:\WINNT\System32\WBEM\WinMgmt.exeUSERENV(1b0.450) 22:14:12:210 LibMain: Process Name: C:\WINNT\system32\spoolsv.exeUSERENV(3b0.3a8) 22:14:13:131 LibMain: Process Name: C:\WINNT\System32\WBEM\WinMgmt.exeUSERENV(d4.260) 22:14:30:716 GetHkeyCU: RegOpenKey failed with error 2USERENV(284.310) 22:14:42:153 LibMain: Process Name: C:\WINNT\System32\WBEM\WinMgmt.exeUSERENV(d4.260) 22:17:25:668 GetHkeyCU: RegOpenKey failed with error 2And Booting without Automatic Logon------------------------------------------USERENV(9c.78) 17:49:04:058 LibMain: Process Name: \??\C:\WINNT\system32\winlogon.exeUSERENV(d4.d0) 17:49:05:049 LibMain: Process Name: C:\WINNT\system32\services.exeUSERENV(e0.dc) 17:49:05:470 LibMain: Process Name: C:\WINNT\system32\lsass.exeUSERENV(e0.dc) 17:49:05:920 LibMain: Process Name: C:\WINNT\system32\lsass.exeUSERENV(194.198) 17:49:07:933 LibMain: Process Name: C:\WINNT\system32\svchost.exeUSERENV(1e4.1e0) 17:49:08:654 LibMain: Process Name: C:\WINNT\system32\EloSrvce.exeUSERENV(200.228) 17:49:08:915 LibMain: Process Name: C:\WINNT\system32\EloLnchr.exeUSERENV(24c.248) 17:49:09:896 LibMain: Process Name: C:\WINNT\system32\MSTask.exeUSERENV(9c.250) 17:49:10:136 ApplyGroupPolicy: Entering. Flags = 7USERENV(9c.250) 17:49:10:156 ProcessGPOs:USERENV(9c.250) 17:49:10:156 ProcessGPOs:USERENV(9c.250) 17:49:10:156 ProcessGPOs: Starting computer Group Policy processing...USERENV(9c.250) 17:49:10:156 ProcessGPOs:USERENV(9c.250) 17:49:10:156 ProcessGPOs:USERENV(9c.250) 17:49:10:156 EnterCriticalPolicySection: Machine critical section has been claimed. Handle = 0x1c0USERENV(9c.250) 17:49:10:156 ProcessGPOs: Machine role is 2.USERENV(9c.250) 17:49:10:166 ProcessGPOs: The DC for domain AUXV is not availableUSERENV(9c.250) 17:49:10:247 LeaveCriticalPolicySection: Critical section 0x1c0 has been released.USERENV(9c.250) 17:49:10:247 ProcessGPOs: Computer Group Policy has been applied.USERENV(9c.250) 17:49:10:247 ProcessGPOs: Leaving with 0.USERENV(9c.250) 17:49:10:247 ApplyGroupPolicy: Leaving successfully.USERENV(9c.23c) 17:49:10:727 GPOThread: Next refresh will happen in 118 minutesUSERENV(1f4.2a4) 17:49:11:649 LibMain: Process Name: C:\WINNT\system32\svchost.exeUSERENV(298.29c) 17:49:11:929 LibMain: Process Name: C:\WINNT\system32\svchost.exeUSERENV(1f4.234) 17:49:14:102 LibMain: Process Name: C:\WINNT\system32\svchost.exeUSERENV(9c.78) 17:49:22:204 =========================================================USERENV(9c.78) 17:49:22:214 LoadUserProfile: Entering, hToken = <0x4e8>, lpProfileInfo = 0x6f648USERENV(9c.78) 17:49:22:214 LoadUserProfile: Entering, hToken = <0x4e8>, lpProfileInfo = 0x6f648USERENV(9c.78) 17:49:22:214 LoadUserProfile: lpProfileInfo->dwFlags = <0x0>USERENV(9c.78) 17:49:22:214 LoadUserProfile: lpProfileInfo->lpUserName = <staff>USERENV(9c.78) 17:49:22:214 LoadUserProfile: lpProfileInfo->lpProfilePath = <\\basement\USER_PROFILES\staff>USERENV(9c.78) 17:49:22:224 LoadUserProfile: lpProfileInfo->lpDefaultPath = <\\BASEMENT\netlogon\Default User>USERENV(9c.78) 17:49:22:224 LoadUserProfile: NULL server nameUSERENV(9c.78) 17:49:22:234 GetUserMutex: enteringUSERENV(9c.78) 17:49:22:254 GetUserMutex: Waiting...USERENV(9c.78) 17:49:22:254 GetUserMutex: Wait succeeded. Mutex currently held.USERENV(9c.78) 17:49:22:254 ParseProfilePath: Entering, lpProfilePath = <\\basement\USER_PROFILES\staff>USERENV(9c.78) 17:49:22:254 CheckXForestLogon: checking x-forest logon, user handle = 1256USERENV(9c.78) 17:49:22:434 MyGetDomainDNSName: Successfully determined fqdn CN=staff,OU=Auxv Staff,DC=auxv,DC=comUSERENV(9c.78) 17:49:22:434 MyGetDomainDNSName: Successfully obtained domain dns name auxv.comUSERENV(9c.78) 17:49:22:434 CheckXForestLogon: not XForest logon.USERENV(9c.78) 17:49:22:554 ParseProfilePath: Tick Count = 0USERENV(9c.78) 17:49:22:564 PingComputer: PingBufferSize set as 2048USERENV(9c.78) 17:49:22:564 PingComputer: First time: 0USERENV(9c.78) 17:49:22:564 PingComputer: Fast link. Exiting.USERENV(9c.78) 17:49:22:564 ParseProfilePath: FindFirstFile found something with attributes <0x10>USERENV(9c.78) 17:49:22:564 ParseProfilePath: Found a directoryUSERENV(9c.78) 17:49:22:564 LoadUserProfile: ParseProfilePath returned a directory of <\\basement\USER_PROFILES\staff>USERENV(9c.78) 17:49:22:564 RestoreUserProfile: EnteringUSERENV(9c.78) 17:49:22:564 IsCentralProfileReachable: EnteringUSERENV(9c.78) 17:49:22:574 CheckRoamingShareOwnership: checking ownership for \\basement\USER_PROFILES\staffUSERENV(9c.78) 17:49:22:584 CheckRoamingShareOwnership: owner is the right userUSERENV(9c.78) 17:49:22:584 IsCentralProfileReachable: Testing <\\basement\USER_PROFILES\staff\ntuser.man>USERENV(9c.78) 17:49:22:604 IsCentralProfileReachable: Profile is not reachable, error = 2USERENV(9c.78) 17:49:22:604 IsCentralProfileReachable: Testing <\\basement\USER_PROFILES\staff\ntuser.dat>USERENV(9c.78) 17:49:22:614 IsCentralProfileReachable: Found a user profile.USERENV(9c.78) 17:49:22:614 RestoreUserProfile: Central Profile is reachableUSERENV(9c.78) 17:49:22:614 RestoreUserProfile: Central Profile is roamingUSERENV(9c.78) 17:49:22:614 RestoreUserProfile: Profile path = <\\basement\USER_PROFILES\staff>USERENV(9c.78) 17:49:22:614 ExtractProfileFromBackup: A profile already existsUSERENV(9c.78) 17:49:22:614 PatchNewProfileIfRequred: A profile already exists with the current sid, exittingUSERENV(9c.78) 17:49:22:614 CreateLocalProfileKey: Not setting additional SecurityUSERENV(9c.78) 17:49:22:614 GetExistingLocalProfileImage: Found entry in profile list for existing local profileUSERENV(9c.78) 17:49:22:614 GetExistingLocalProfileImage: Local profile image filename = <%SystemDrive%\Documents and Settings\staff>USERENV(9c.78) 17:49:22:624 GetExistingLocalProfileImage: Expanded local profile image filename = <C:\Documents and Settings\staff>USERENV(9c.78) 17:49:22:664 GetExistingLocalProfileImage: No local mandatory profile. Error = 2USERENV(9c.78) 17:49:22:664 GetExistingLocalProfileImage: Found local profile image file ok <C:\Documents and Settings\staff\ntuser.dat>USERENV(9c.78) 17:49:22:664 Local Existing Profile Image is reachableUSERENV(9c.78) 17:49:22:664 Local profile name is <C:\Documents and Settings\staff>USERENV(9c.78) 17:49:22:664 RestoreUserProfile: Reconciling roaming profile with local profileUSERENV(9c.78) 17:49:22:705 GetExclusionList: The exclusion lists on both server and client are the same. The list is: <Local Settings;Temporary Internet Files;History;Temp;>USERENV(9c.78) 17:49:22:725 CopyProfileDirectoryEx: Entering, lpSourceDir = <\\basement\USER_PROFILES\staff>, lpDestinationDir = <C:\Documents and Settings\staff>, dwFlags = 0x4c20USERENV(9c.78) 17:49:22:725 CopyProfileDirectoryEx: lpExclusionList = <Local Settings;Temporary Internet Files;History;Temp;>USERENV(9c.78) 17:49:22:725 ConvertExclusionList: Adding \\basement\USER_PROFILES\staff\Local Settings to ExclusionListUSERENV(9c.78) 17:49:22:725 ConvertExclusionList: Adding \\basement\USER_PROFILES\staff\Temporary Internet Files to ExclusionListUSERENV(9c.78) 17:49:22:725 ConvertExclusionList: Adding \\basement\USER_PROFILES\staff\History to ExclusionListUSERENV(9c.78) 17:49:22:725 ConvertExclusionList: Adding \\basement\USER_PROFILES\staff\Temp to ExclusionListUSERENV(9c.78) 17:49:22:725 ConvertExclusionList: Adding C:\Documents and Settings\staff\Local Settings to ExclusionListUSERENV(9c.78) 17:49:22:725 ConvertExclusionList: Adding C:\Documents and Settings\staff\Temporary Internet Files to ExclusionListUSERENV(9c.78) 17:49:22:725 ConvertExclusionList: Adding C:\Documents and Settings\staff\History to ExclusionListUSERENV(9c.78) 17:49:22:725 ConvertExclusionList: Adding C:\Documents and Settings\staff\Temp to ExclusionListUSERENV(9c.78) 17:49:22:755 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Application Data\Identities\{4BE204E8-A755-443C-B6F4-569426913F01}\ to the list of directoriesUSERENV(9c.78) 17:49:22:755 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Application Data\Identities\ to the list of directoriesUSERENV(9c.78) 17:49:22:775 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Application Data\Microsoft\Address Book\ to the list of directoriesUSERENV(9c.78) 17:49:22:805 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Application Data\Microsoft\Internet Explorer\Quick Launch\ to the list of directoriesUSERENV(9c.78) 17:49:22:805 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Application Data\Microsoft\Internet Explorer\ to the list of directoriesUSERENV(9c.78) 17:49:22:825 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Application Data\Microsoft\Protect\S-1-5-21-1292428093-113007714-839522115-1110\ to the list of directoriesUSERENV(9c.78) 17:49:22:825 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Application Data\Microsoft\Protect\ to the list of directoriesUSERENV(9c.78) 17:49:22:835 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Application Data\Microsoft\SystemCertificates\My\Certificates\ to the list of directoriesUSERENV(9c.78) 17:49:22:845 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Application Data\Microsoft\SystemCertificates\My\CRLs\ to the list of directoriesUSERENV(9c.78) 17:49:22:855 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Application Data\Microsoft\SystemCertificates\My\CTLs\ to the list of directoriesUSERENV(9c.78) 17:49:22:855 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Application Data\Microsoft\SystemCertificates\My\ to the list of directoriesUSERENV(9c.78) 17:49:22:855 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Application Data\Microsoft\SystemCertificates\ to the list of directoriesUSERENV(9c.78) 17:49:22:855 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Application Data\Microsoft\ to the list of directoriesUSERENV(9c.78) 17:49:22:855 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Application Data\ to the list of directoriesUSERENV(9c.78) 17:49:22:875 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Cookies\ to the list of directoriesUSERENV(9c.78) 17:49:22:875 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Desktop\ to the list of directoriesUSERENV(9c.78) 17:49:22:895 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Favorites\Links\ to the list of directoriesUSERENV(9c.78) 17:49:22:905 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Favorites\Media\ to the list of directoriesUSERENV(9c.78) 17:49:22:905 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Favorites\ to the list of directoriesUSERENV(9c.78) 17:49:22:915 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\My Documents\My Pictures\ to the list of directoriesUSERENV(9c.78) 17:49:22:915 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\My Documents\ to the list of directoriesUSERENV(9c.78) 17:49:22:925 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\NetHood\Computers Near Me\ to the list of directoriesUSERENV(9c.78) 17:49:22:935 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\NetHood\ to the list of directoriesUSERENV(9c.78) 17:49:22:935 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\PrintHood\ to the list of directoriesUSERENV(9c.78) 17:49:22:945 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Recent\ to the list of directoriesUSERENV(9c.78) 17:49:22:945 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\SendTo\ to the list of directoriesUSERENV(9c.78) 17:49:22:995 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Start Menu\Programs\Accessories\Accessibility\ to the list of directoriesUSERENV(9c.78) 17:49:23:015 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Start Menu\Programs\Accessories\System Tools\ to the list of directoriesUSERENV(9c.78) 17:49:23:015 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Start Menu\Programs\Accessories\ to the list of directoriesUSERENV(9c.78) 17:49:23:025 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Start Menu\Programs\Startup\ to the list of directoriesUSERENV(9c.78) 17:49:23:025 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Start Menu\Programs\ to the list of directoriesUSERENV(9c.78) 17:49:23:025 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Start Menu\ to the list of directoriesUSERENV(9c.78) 17:49:23:045 RecurseDirectory: Adding \\basement\USER_PROFILES\staff\Templates\ to the list of directoriesUSERENV(9c.78) 17:49:23:055 RecurseDirectory: Adding C:\Documents and Settings\staff\Application Data\Identities\{4BE204E8-A755-443C-B6F4-569426913F01}\ to the list of directoriesUSERENV(9c.78) 17:49:23:055 RecurseDirectory: Adding C:\Documents and Settings\staff\Application Data\Identities\ to the list of directoriesUSERENV(9c.78) 17:49:23:085 RecurseDirectory: Adding C:\Documents and Settings\staff\Application Data\Microsoft\Address Book\ to the list of directoriesUSERENV(9c.78) 17:49:23:115 RecurseDirectory: Adding C:\Documents and Settings\staff\Application Data\Microsoft\Internet Explorer\Quick Launch\ to the list of directoriesUSERENV(9c.78) 17:49:23:115 RecurseDirectory: Adding C:\Documents and Settings\staff\Application Data\Microsoft\Internet Explorer\ to the list of directoriesUSERENV(9c.78) 17:49:23:115 RecurseDirectory: Adding C:\Documents and Settings\staff\Application Data\Microsoft\Protect\S-1-5-21-1292428093-113007714-839522115-1110\ to the list of directoriesUSERENV(9c.78) 17:49:23:125 RecurseDirectory: Adding C:\Documents and Settings\staff\Application Data\Microsoft\Protect\ to the list of directoriesUSERENV(9c.78) 17:49:23:125 RecurseDirectory: Adding C:\Documents and Settings\staff\Application Data\Microsoft\SystemCertificates\My\Certificates\ to the list of directoriesUSERENV(9c.78) 17:49:23:125 RecurseDirectory: Adding C:\Documents and Settings\staff\Application Data\Microsoft\SystemCertificates\My\CRLs\ to the list of directoriesUSERENV(9c.78) 17:49:23:125 RecurseDirectory: Adding C:\Documents and Settings\staff\Application Data\Microsoft\SystemCertificates\My\CTLs\ to the list of directoriesUSERENV(9c.78) 17:49:23:125 RecurseDirectory: Adding C:\Documents and Settings\staff\Application Data\Microsoft\SystemCertificates\My\ to the list of directoriesUSERENV(9c.78) 17:49:23:135 RecurseDirectory: Adding C:\Documents and Settings\staff\Application Data\Microsoft\SystemCertificates\ to the list of directoriesUSERENV(9c.78) 17:49:23:135 RecurseDirectory: Adding C:\Documents and Settings\staff\Application Data\Microsoft\ to the list of directoriesUSERENV(9c.78) 17:49:23:135 RecurseDirectory: Adding C:\Documents and Settings\staff\Application Data\ to the list of directoriesUSERENV(9c.78) 17:49:23:145 RecurseDirectory: Adding C:\Documents and Settings\staff\Cookies\ to the list of directoriesUSERENV(9c.78) 17:49:23:155 RecurseDirectory: Adding C:\Documents and Settings\staff\Desktop\ to the list of directoriesUSERENV(9c.78) 17:49:23:185 RecurseDirectory: Adding C:\Documents and Settings\staff\Favorites\Links\ to the list of directoriesUSERENV(9c.78) 17:49:23:225 RecurseDirectory: Adding C:\Documents and Settings\staff\Favorites\Media\ to the list of directoriesUSERENV(9c.78) 17:49:23:225 RecurseDirectory: Adding C:\Documents and Settings\staff\Favorites\ to the list of directoriesUSERENV(9c.78) 17:49:23:225 RecurseDirectory: Skipping <C:\Documents and Settings\staff\Local Settings> due to exclusion list.USERENV(9c.78) 17:49:23:235 RecurseDirectory: Adding C:\Documents and Settings\staff\My Documents\My Pictures\ to the list of directoriesUSERENV(9c.78) 17:49:23:235 RecurseDirectory: Adding C:\Documents and Settings\staff\My Documents\ to the list of directoriesUSERENV(9c.78) 17:49:23:235 RecurseDirectory: Adding C:\Documents and Settings\staff\NetHood\Computers Near Me\ to the list of directoriesUSERENV(9c.78) 17:49:23:235 RecurseDirectory: Adding C:\Documents and Settings\staff\NetHood\ to the list of directoriesUSERENV(9c.78) 17:49:23:245 RecurseDirectory: Adding C:\Documents and Settings\staff\PrintHood\ to the list of directoriesUSERENV(9c.78) 17:49:23:245 RecurseDirectory: Adding C:\Documents and Settings\staff\Recent\ to the list of directoriesUSERENV(9c.78) 17:49:23:295 RecurseDirectory: Adding C:\Documents and Settings\staff\SendTo\ to the list of directoriesUSERENV(9c.78) 17:49:23:335 RecurseDirectory: Adding C:\Documents and Settings\staff\Start Menu\Programs\Accessories\Accessibility\ to the list of directoriesUSERENV(9c.78) 17:49:23:345 RecurseDirectory: Adding C:\Documents and Settings\staff\Start Menu\Programs\Accessories\System Tools\ to the list of directoriesUSERENV(9c.78) 17:49:23:355 RecurseDirectory: Adding C:\Documents and Settings\staff\Start Menu\Programs\Accessories\ to the list of directoriesUSERENV(9c.78) 17:49:23:355 RecurseDirectory: Adding C:\Documents and Settings\staff\Start Menu\Programs\Startup\ to the list of directoriesUSERENV(9c.78) 17:49:23:355 RecurseDirectory: Adding C:\Documents and Settings\staff\Start Menu\Programs\ to the list of directoriesUSERENV(9c.78) 17:49:23:355 RecurseDirectory: Adding C:\Documents and Settings\staff\Start Menu\ to the list of directoriesUSERENV(9c.78) 17:49:23:375 RecurseDirectory: Adding C:\Documents and Settings\staff\Templates\ to the list of directoriesUSERENV(9c.78) 17:49:23:395 CopyProfileDirectoryEx: Calling ReconcileDirectory for all DirectoriesUSERENV(9c.78) 17:49:24:247 CopyProfileDirectoryEx: Reconcile Directory Done for all DirectoriesUSERENV(9c.78) 17:49:24:367 SyncItems: New file or directory <C:\Documents and Settings\staff\Desktop\userenv.log> in destination since this profile was loaded. This will NOT be deleted.USERENV(9c.78) 17:49:24:367 CopyProfileDirectoryEx: Setting Directory TimeStamps all DirectoriesUSERENV(9c.78) 17:49:24:387 CopyProfileDirectoryEx: Set times on all directoriesUSERENV(9c.78) 17:49:24:417 CopyProfileDirectoryEx: Leaving with a return value of 1USERENV(9c.78) 17:49:24:547 MyRegLoadKey: Mutex released. Returning 0.USERENV(9c.78) 17:49:24:687 MyRegLoadKey: Mutex released. Returning 0.USERENV(9c.78) 17:49:24:687 CreateClassHive: existing user classes hive foundUSERENV(9c.78) 17:49:24:717 RestoreUserProfile: About to Leave. Final Information follows:USERENV(9c.78) 17:49:24:717 Profile was successfully loaded.USERENV(9c.78) 17:49:24:717 lpProfile->lpRoamingProfile = <\\basement\USER_PROFILES\staff>USERENV(9c.78) 17:49:24:717 lpProfile->lpLocalProfile = <C:\Documents and Settings\staff>USERENV(9c.78) 17:49:24:717 lpProfile->dwInternalFlags = 0x10USERENV(9c.78) 17:49:24:717 RestoreUserProfile: Leaving.USERENV(9c.78) 17:49:24:717 UpgradeProfile: EnteringUSERENV(9c.78) 17:49:24:727 UpgradeProfile: Build numbers matchUSERENV(9c.78) 17:49:24:727 UpgradeProfile: Leaving SuccessfullyUSERENV(9c.78) 17:49:24:727 LoadUserProfile: Releasing mutex.USERENV(9c.78) 17:49:24:727 LoadUserProfile: Leaving with a value of 1.USERENV(9c.78) 17:49:24:727 LoadUserProfile: hProfile = <0x360>USERENV(9c.78) 17:49:24:727 =========================================================USERENV(9c.324) 17:49:24:948 ApplyGroupPolicy: Entering. Flags = 6USERENV(9c.324) 17:49:24:948 ProcessGPOs:USERENV(9c.324) 17:49:24:948 ProcessGPOs:USERENV(9c.324) 17:49:24:948 ProcessGPOs: Starting user Group Policy processing...USERENV(9c.324) 17:49:24:948 ProcessGPOs:USERENV(9c.324) 17:49:24:948 ProcessGPOs:USERENV(9c.324) 17:49:24:948 EnterCriticalPolicySection: User critical section has been claimed. Handle = 0x2f8USERENV(9c.324) 17:49:24:948 ProcessGPOs: Machine role is 2.USERENV(9c.324) 17:49:24:958 PingComputer: PingBufferSize set as 2048USERENV(9c.324) 17:49:24:958 PingComputer: First time: 0USERENV(9c.324) 17:49:24:958 PingComputer: Fast link. Exiting.USERENV(9c.324) 17:49:24:958 ProcessGPOs: User name is: CN=staff,OU=Auxv Staff,DC=auxv,DC=com, Domain name is: AUXVUSERENV(9c.324) 17:49:24:968 ProcessGPOs: Domain controller is: \\basement.auxv.com Domain DN is auxv.comUSERENV(9c.324) 17:49:25:098 MyGetDomainDNSName: Successfully determined fqdn CN=staff,OU=Auxv Staff,DC=auxv,DC=comUSERENV(9c.324) 17:49:25:098 MyGetDomainDNSName: Successfully obtained domain dns name auxv.comUSERENV(9c.324) 17:49:25:108 ProcessGPOs: Calling GetGPOInfo for normal policy modeUSERENV(9c.324) 17:49:25:108 GetGPOInfo: ********************************USERENV(9c.324) 17:49:25:108 GetGPOInfo: Entering...USERENV(9c.324) 17:49:25:118 GetGPOInfo: Server connection established.USERENV(9c.324) 17:49:25:138 GetGPOInfo: Bound successfully.USERENV(9c.324) 17:49:25:148 SearchDSObject: Searching <OU=Auxv Staff,DC=auxv,DC=com>USERENV(9c.324) 17:49:25:158 SearchDSObject: Found GPO(s): <[LDAP://CN={EA25CBE8-B7DD-42EF-99C0-7055C637F773},CN=Policies,CN=System,DC=auxv,DC=com;1]>USERENV(9c.324) 17:49:25:158 SearchDSObject: The link to GPO LDAP://CN={EA25CBE8-B7DD-42EF-99C0-7055C637F773},CN=Policies,CN=System,DC=auxv,DC=com is disabled. It will be skipped.USERENV(9c.324) 17:49:25:158 SearchDSObject: Searching <DC=auxv,DC=com>USERENV(9c.324) 17:49:25:158 SearchDSObject: Found GPO(s): <[LDAP://CN={31B2F340-016D-11D2-945F-00C04FB984F9},CN=Policies,CN=System,DC=auxv,DC=com;0]>USERENV(9c.324) 17:49:25:168 ProcessGPO: ==============================USERENV(9c.324) 17:49:25:168 ProcessGPO: Deferring search for <LDAP://CN={31B2F340-016D-11D2-945F-00C04FB984F9},CN=Policies,CN=System,DC=auxv,DC=com>USERENV(9c.324) 17:49:25:198 SearchDSObject: Searching <CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=auxv,DC=com>USERENV(9c.324) 17:49:25:198 SearchDSObject: No GPO(s) for this object.USERENV(9c.324) 17:49:25:198 EvaluateDeferredGPOs: Searching for GPOs in cn=policies,cn=system,DC=auxv,DC=comUSERENV(9c.324) 17:49:25:208 ProcessGPO: ==============================USERENV(9c.324) 17:49:25:208 ProcessGPO: Searching <CN={31B2F340-016D-11D2-945F-00C04FB984F9},CN=Policies,CN=System,DC=auxv,DC=com>USERENV(9c.324) 17:49:25:208 ProcessGPO: User has access to this GPO.USERENV(9c.324) 17:49:25:208 ProcessGPO: Found functionality version of: 2USERENV(9c.324) 17:49:25:208 ProcessGPO: Found file system path of: <\\auxv.com\sysvol\auxv.com\Policies\{31B2F340-016D-11D2-945F-00C04FB984F9}>USERENV(9c.324) 17:49:25:248 ProcessGPO: Found common name of: <{31B2F340-016D-11D2-945F-00C04FB984F9}>USERENV(9c.324) 17:49:25:248 ProcessGPO: Found display name of: <Default Domain Policy>USERENV(9c.324) 17:49:25:248 ProcessGPO: Found user version of: GPC is 1, GPT is 1USERENV(9c.324) 17:49:25:248 ProcessGPO: Found flags of: 0USERENV(9c.324) 17:49:25:248 ProcessGPO: Found extensions: [{3060E8D0-7020-11D2-842D-00C04FA372D4}{3060E8CE-7020-11D2-842D-00C04FA372D4}]USERENV(9c.324) 17:49:25:248 ProcessGPO: ==============================USERENV(9c.324) 17:49:25:268 GetGPOInfo: GPO Local Group Policy doesn't contain any data since the version number is 0. It will be skipped.USERENV(9c.324) 17:49:25:268 GetGPOInfo: Leaving with 1USERENV(9c.324) 17:49:25:278 GetGPOInfo: ********************************USERENV(9c.324) 17:49:25:278 ProcessGPOs: OpenThreadToken failed with error 1008, assuming thread is not impersonatingUSERENV(9c.324) 17:49:25:278 ProcessGPOs: -----------------------USERENV(9c.324) 17:49:25:278 ProcessGPOs: Processing extension RegistryUSERENV(9c.324) 17:49:25:278 CompareGPOLists: The lists are the same.USERENV(9c.324) 17:49:25:278 CheckGPOs: No GPO changes and no security group membership change and extension Registry has NoGPOChanges set.USERENV(9c.324) 17:49:25:278 ProcessGPOs: -----------------------USERENV(9c.324) 17:49:25:298 ProcessGPOs: -----------------------USERENV(9c.324) 17:49:25:298 ProcessGPOs: Processing extension Folder RedirectionUSERENV(9c.324) 17:49:25:298 CompareGPOLists: The lists are the same.USERENV(9c.324) 17:49:25:298 CheckGPOs: No GPO changes but couldn't read extension Folder Redirection's status or policy time.USERENV(9c.324) 17:49:25:308 ProcessGPOs: Extension Folder Redirection skipped because both deleted and changed GPO lists are empty.USERENV(9c.324) 17:49:25:308 ProcessGPOs: -----------------------USERENV(9c.324) 17:49:25:308 ProcessGPOs: Processing extension Microsoft Disk QuotaUSERENV(9c.324) 17:49:25:308 ProcessGPOs: Extension Microsoft Disk Quota skipped with flags 0x6.USERENV(9c.324) 17:49:25:308 ProcessGPOs: -----------------------USERENV(9c.324) 17:49:25:308 ProcessGPOs: Processing extension ScriptsUSERENV(9c.324) 17:49:25:308 CompareGPOLists: The lists are the same.USERENV(9c.324) 17:49:25:308 CheckGPOs: No GPO changes but couldn't read extension Scripts's status or policy time.USERENV(9c.324) 17:49:25:318 ProcessGPOs: Extension Scripts skipped because both deleted and changed GPO lists are empty.USERENV(9c.324) 17:49:25:318 ProcessGPOs: -----------------------USERENV(9c.324) 17:49:25:318 ProcessGPOs: Processing extension SecurityUSERENV(9c.324) 17:49:25:318 ProcessGPOs: Extension Security skipped with flags 0x6.USERENV(9c.324) 17:49:25:318 ProcessGPOs: -----------------------USERENV(9c.324) 17:49:25:318 ProcessGPOs: Processing extension Internet Explorer BrandingUSERENV(9c.324) 17:49:25:318 CompareGPOLists: The lists are the same.USERENV(9c.324) 17:49:25:318 CheckGPOs: No GPO changes but couldn't read extension Internet Explorer Branding's status or policy time.USERENV(9c.324) 17:49:25:328 ProcessGPOs: Extension Internet Explorer Branding skipped because both deleted and changed GPO lists are empty.USERENV(9c.324) 17:49:25:328 ProcessGPOs: -----------------------USERENV(9c.324) 17:49:25:328 ProcessGPOs: Processing extension EFS recoveryUSERENV(9c.324) 17:49:25:328 ProcessGPOs: Extension EFS recovery skipped with flags 0x6.USERENV(9c.324) 17:49:25:328 ProcessGPOs: -----------------------USERENV(9c.324) 17:49:25:328 ProcessGPOs: Processing extension Application ManagementUSERENV(9c.324) 17:49:25:328 CompareGPOLists: The lists are the same.USERENV(9c.324) 17:49:25:328 CheckGPOs: No GPO changes but couldn't read extension Application Management's status or policy time.USERENV(9c.324) 17:49:25:328 ProcessGPOs: Extension Application Management skipped because both deleted and changed GPO lists are empty.USERENV(9c.324) 17:49:25:338 ProcessGPOs: -----------------------USERENV(9c.324) 17:49:25:338 ProcessGPOs: Processing extension IP SecurityUSERENV(9c.324) 17:49:25:338 ProcessGPOs: Extension IP Security skipped with flags 0x6.USERENV(9c.324) 17:49:25:338 LeaveCriticalPolicySection: Critical section 0x2f8 has been released.USERENV(9c.324) 17:49:25:338 ProcessGPOs: User Group Policy has been applied.USERENV(9c.324) 17:49:25:338 ProcessGPOs: Leaving with 1.USERENV(9c.324) 17:49:25:338 ApplyGroupPolicy: Leaving successfully.USERENV(9c.33c) 17:49:25:549 GPOThread: Next refresh will happen in 119 minutesUSERENV(350.34c) 17:49:26:159 LibMain: Process Name: C:\WINNT\system32\userinit.exeUSERENV(d4.1cc) 17:49:26:280 ImpersonateUser: Failed to impersonate user with 5.USERENV(d4.1cc) 17:49:26:280 GetUserNameAndDomain Failed to impersonate userUSERENV(334.330) 17:49:27:081 LibMain: Process Name: C:\WINNT\System32\WBEM\WinMgmt.exeUSERENV(358.380) 17:49:28:403 LibMain: Process Name: C:\WINNT\Explorer.EXEUSERENV(368.3a8) 17:49:30:366 LibMain: Process Name: C:\WINNT\system32\mobsync.exeUSERENV(3d4.3d0) 17:49:31:477 LibMain: Process Name: C:\WINNT\system32\EloDkMon.exeUSERENV(3ec.3e8) 17:49:31:577 LibMain: Process Name: C:\WINNT\system32\EloTTray.exeUSERENV(3f4.3f0) 17:49:32:509 LibMain: Process Name: C:\WINNT\system32\EloRtBtn.exeUSERENV(200.22c) 17:49:32:659 LibMain: Process Name: C:\WINNT\system32\EloLnchr.exeUSERENV(1b0.450) 17:49:40:150 LibMain: Process Name: C:\WINNT\system32\spoolsv.exeUSERENV(334.330) 17:49:41:061 LibMain: Process Name: C:\WINNT\System32\WBEM\WinMgmt.exeUSERENV(288.3e0) 17:50:02:742 LibMain: Process Name: C:\WINNT\System32\WBEM\WinMgmt.exeUSERENV(d4.264) 17:50:06:578 GetHkeyCU: RegOpenKey failed with error 2
BattlePanic Posted August 4, 2007 Author Posted August 4, 2007 After some more testing I think I may have narrowed the problem. I've discovered that two of the workstations boot just fine using automatic logon and they are able to retrieve their roaming profile from the network share. The third terminal, and the one upon which I had been conducting my tests, has an integrated ethernet adapter which isn't working. As a workaround, I had installed a Linksys USB200M usb to ethernet adapter. This adapter was a simple fix but it appears to be unable to contact the network share when an automatic logon is performed. I don't know if this has something to do with the sequence in which these particular drivers are loaded or perhaps it's that I'm using a USB 1.1 slot which is slower than your usual 100 megabit per second ethernet connection.I'm sure this problem hasn't come up much but if anyone has any thoughts on a potential solution let me know.
